First post, by sdz
Someone kindly gave me this card some time ago, and since I got the 5500 PCI working, I thought to give this one a shot.
It looks bad, but the PCB is in quite good shape:
The attachment 20231216_143739.jpg is no longer available
The attachment 20231216_143800.jpg is no longer available
First step is to give it a proper wash (IPA followed by soapy water) and see what we're working with:
The attachment 20231216_174001.jpg is no longer available
The attachment 20231216_174009.jpg is no longer available
Not that bad, next step is to clean any solder short (right VSA),add the missing 14.318MHz crystal for the master VSA, replace that "aftermarket" inductor, and add the missing RAM for the master VSA (the existing bottom one also needs resoldering as someone attempted to remove it at some point), add missing Q5/Q6, the two ceramic caps underneath the PMIC and various missing resistors on the card.
Reply 1 of 15, by sdz
Did all that and all that it does is preventing the system to boot.
The attachment 20231216_184834.jpg is no longer available
The attachment 20231216_184843.jpg is no longer available
The attachment 20231216_185257.jpg is no longer available
Reply 2 of 15, by sdz
Power rails were Ok, measured all resistors on the card and they were OK, eventually I discovered that the flash had two data pins shorted together, and after fixing that:
The attachment 20231216_200744.jpg is no longer available
Signs of life!
Reply 3 of 15, by GRIFF
Good work. Respect.
Reply 4 of 15, by sdz
Thanks!
There's still a bit of work to be done, but at the moment the card works in single VSA mode:
The attachment 20231216_205220.jpg is no longer available
The attachment 20231216_205251.jpg is no longer available
Image is a bit wonky, but that's due to all those missing caps. It's also very bright, but that's normal for a V5 AGP/PCI on VGA output when the slave VSA is missing.
The master VSA and memory appear to work fine.
Time to add all the missing caps, VSA and 2 RAM ICs.
Reply 5 of 15, by GRIFF
You have another GPU to soldering?
Reply 6 of 15, by sdz
I have a couple, but I'll probably replace it tomorrow.
I already replaced everything else.
Reply 7 of 15, by sdz
I really couldn't wait until tomorrow, so I soldered the VSA.
The attachment 20231216_224812.jpg is no longer available
The attachment 20231216_224821.jpg is no longer available
The attachment 20231216_223358.jpg is no longer available
Good news: both VSAs appear to be working fine
Bad news: VGA output is still too bright and extremely nosiy at some resolutions.
Reply 9 of 15, by sdz
Thanks! I use Chipquik NC191.
For cleaning I soak the board in IPA for a bit, then brush it, and while it's still wet I wash it with hot water(tap) and a brush. After you properly dry it, it looks perfect (unlike the card in my pictures, I'll give it a proper clean after I get it working).
Sometimes I also ultrasonic clean them, but filling and emptying the big ultrasonic cleaner is a pain.
Reply 10 of 15, by sdz
Added cooling and ran some benchmarks:
Single VSA:
The attachment 20231217_010759.jpg is no longer available
Dual VSA:
The attachment 20231217_011459.jpg is no longer available
During the benchmark the image is perfect, just way too bright. I'll check the VSA databook, there has to be some voltage/current reference for the integrated RAMDAC.
Edit:
Well, fixed the brightness issue.
The attachment 20231217_014157.jpg is no longer available
R543 should be 31R not 5R.
What remains in noise in 2D and 3D mode.
1024x768, 1920x1080 and 1600x1024 are perfect, but anything else has horizontal jitter.
Could also be the crappy Dell LCD.
Edit 2:
It's the crappy Dell. It does the same thing with other VSA cards, and the image looks perfect at any resolution through a VGA to HDMI converter.
So it looks like the card works fine and can be considered fixed. I'll manufacure a PCI bracket for it and replace the 2.54mm pin header & VGA connector, as someone previously melted them, as well as the power connector, which looks quite nasty.
Also need to add some heatsinks/fans.
Reply 11 of 15, by danieljm
Amazing work. Well done.
Reply 12 of 15, by igna78
Only a word for all: FANTASTIC!
Reply 13 of 15, by GRIFF
Bravo!!!!!
Reply 14 of 15, by analog_programmer
Impressive work. What equipment did you use for reballing and soldering of the missing VSA chip?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 15 of 15, by sdz
Thanks guys!
@analog_programmer
Just a preheater and hot air station. Any will do.
For reballing, a reballing jig and a custom stencil (you can order one from JLC).
