First post, by xtreger
Hi all, I recently got a Radeon X850 Pro AGP card to put in a Windows 98 system. I've heard that it has 12 pixel pipelines unlocked, but apparently in some cases 16 pipelines can be unlocked too, by flashing some ROM or something.
The part number of my card is 102A4751100. I have a friend who has experience in flashing BIOS and all, and on my end I'm willing to learn too. So if anyone knows how to unlock 16 pipelines in X850 Pro, could you please give me detailed steps, or point me to some source that explains how to do so?
I want the best Win98 gaming experience. Thanks!
Reply 1 of 8, by Sphere478
Sometimes they are disabled because they aren’t good but often times they are unlockable.
Try a bios flash and see.
I forget the steps but used to do it often back in the day.
Sphere's PCB projects.
Reply 2 of 8, by xtreger
Sphere478 wrote on 2023-12-16, 17:31:
A couple of doubts: do you know of a way to check if the gfx card is disabled or if it's unlockable?
Secondly, could you elaborate a bit on "Try a bios flash and see"?
Reply 4 of 8, by Trashbytes
IIRC it was only the VIVO versions that could be unlocked, so if yours doesnt have Video in Video Out then it cant be unlocked.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 7 of 8, by Sphere478
Check techpowerup for a bios for a x850xt with the same bus and memory size as yours
I think there may be an app called atiwinflash
Reply 8 of 8, by The Serpent Rider
ATI tool can check if they are locked on firmware or hardware level. Generally, most X850 are locked by laser etching. VIVO or not.
