First post, by NarakuITA
I have a problem with the stylus of the Palm m100 that I received from ebay. Basically when I synced the Palm with the PC IBM 330 with Windows 95, all the information was synced. However, when turning on the handheld, unfortunately the precision of the stylus is completely off-set. Since it isn't precise, I can't start the "welcome" program to reconfigure the precision of the stylus. How can I do? The PDA is unusable!
I may not synchronize it with the PC, but this handheld device once the battery is empty and needs to be changed, loses all its information inside it, which is why it is necessary to synchronize it with the PC, so as not to lose all the data inside it . I don't know what I can do...
