First post, by eugrus
Dosbox (0.74-3) on Debian 12 (Xorg) crushes on return to windowed mode from fullscreen (Alt+Enter)
X Error of failed request:  BadValue (integer parameter out of range for operation)
Major opcode of failed request: 153 (XFree86-VidModeExtension)
Minor opcode of failed request: 10 (XF86VidModeSwitchToMode)
Value in failed request: 0x5800003
Serial number of failed request: 267
Current serial number in output stream: 269
In the process it fails to reset the screen resolution back, so I have to manually run xrandr
Reply 1 of 3, by dominusprog
Try DOSBox Staging.
sudo apt install libsdl2-2.0-0 libsdl2-image-2.0-0 libsdl2-net-2.0-0 libopusfile0
https://dosbox-staging.github.io/downloads/linux/
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 3, by eugrus
p.s.: the bug appears to manifest itself under Cinnamon, but not under KDE
Reply 3 of 3, by giantclam
Possibly the compositor in Cinnamon?
