First post, by Frank
Frank
Offline
I would like to swap the 80Mhz RamDAC for a 110Mhz RamDAC on an ET4000W32i ISA card. I once read that the clock generator chip ICS2494 can provide up to 135Mhz? Is this a pure software problem with the driver or do you have to change the external circuitry of the ICS2494 chip?
