First post, by AlessandroB
My last controller is just arrived but i have encountered a problem… please check the pics.
no drive attached ?
Do not ask Why !
What card is it in reality?
ElectroSoldier wrote on 2023-12-27, 19:57:What card is it in reality?
this
The bios doesn't get installed because there is no device on the scsi bus that requires bios services to be installed.
Do not ask Why !
Is there a device on the SCSI bus?
I mean I know there isnt because it would come up but is there something attached?
weedeewee wrote on 2023-12-27, 19:14:no drive attached ?
tries without, whit a hard disk drive 68pin and with a cd-rom scsi 50pin
ElectroSoldier wrote on 2023-12-27, 20:30:Is there a device on the SCSI bus?
scsi 50pin to 68pin adapter -> scsi cable (i think lvd) -> hard disk 15k -> at the end of the cable there is a terminator.
AlessandroB wrote on 2023-12-27, 20:33:weedeewee wrote on 2023-12-27, 19:14:no drive attached ?
Sorry, I was looking at the 'bios not installed' message and overlooked the line above it.
and sorry again, but no clue other than, wrong bios ? weird.
Do not ask Why !
weedeewee wrote on 2023-12-27, 20:28:The bios doesn't get installed because there is no device on the scsi bus that requires bios services to be installed.
possible incompatibility with cable-adapter-terminator? But the message say something like “your card have installed a wrong bios”
AlessandroB wrote on 2023-12-27, 20:37:weedeewee wrote on 2023-12-27, 20:28:The bios doesn't get installed because there is no device on the scsi bus that requires bios services to be installed.
try changing the dipswitch 5 to en/disable the floppy controller ?
Do not ask Why !
weedeewee wrote on 2023-12-27, 20:41:AlessandroB wrote on 2023-12-27, 20:37:weedeewee wrote on 2023-12-27, 20:28:The bios doesn't get installed because there is no device on the scsi bus that requires bios services to be installed.
no is disable, i will try tomorrow. can be a resource conflict that make the problem? is set switch default.
Very odd, my thought is same as above, try enabling floppy controller on dip.
I would say looking at the message that somebody has installed the wrong BIOS to the card.
However having just checked the BIOS for the AHA-1540C and the AHA-1540CF and AHA-1542CF and AHA-1542C is the same BIOS...
Im not sure...
Maybe make sure your system BIOS is setup correctly ie it is allowing interrupts to the card etc...
If that is all ok then maybe flash the card to the latest BIOS. But before you do make triple sure the system BIOS is set up properly. Its amazing the amount of times it isnt and your system will run anyway.
possibly wrong firmware, tells you straight "1542C and 1542CF arent interchangeable". example problems with 1542B Re: Showing some love for Adaptec's ugly ducklings: Adding big drive support to EISA and VL controllers
https://github.com/raszpl/440BX Reference Design adapted to Kicad
rasz_pl wrote on 2023-12-27, 21:08:Wrong firmware 1542C ad 1542CF arent interchangeable Re: Showing some love for Adaptec's ugly ducklings: Adding big drive support to EISA and VL controllers
But the Microsemi site directs you to the same download for each of the cards BIOS.
Is it wrong?
I edited my message. When firmware straight up says "1542CF not intended for 1542C" I would believe it.
rasz_pl wrote on 2023-12-27, 21:12:I edited my message. When firmware straight up says "1542CF not intended for 1542C" I would believe it.
Oh I agree with you. I have come across this problem before, but the card is a 1542CF, but the firmware message stats that its a 1542C...
Thats why my first question is what card it actually is.
Dont forget this chap is trying to run an large hard disk on it...
I would try removing the hard disk from the SCSI chain. Just stick a CDROM drive on it and see what happens. because it might not be the wrong BIOS at all. And updating the BIOS to the BIOS Adaptec say it should be running shouldnt cause any problems.
FYI Re: Adaptec 1542CF…. big problem
edit, maybe the little eeprom is slightly corrupted, making the bios think the card is a 1542C.
Do not ask Why !
firmware dumps for C CF and CP variants https://minuszerodegrees.net/rom/rom.htm
