First post, by Jackhead
So i build me a SNES controller with a Parallel cable to use with sneskey on dos.
First question what LPT mode should i choose for sneskey, ECP/EPP/Normal?
Next question about the IRQ. I have two soundboards installed IRQ 5/7 so im not sure if this work sharing with LPT?
Win98SE: Asus XG DLS - 1x P3 Xeon SL4XY 900/100/2- SG Voodoo 5 6000 PCI - 1GB RAM ECC- Diamond Monster Sound MX300 - Roland MPU-401AT (Yucatan FX)
Reply 2 of 3, by Jo22
The question wasn't that wrong, though.
I've assumed SNESKey would just use printer status pins for reading data, but pin 2 is DATA 0 and Pin 3 is DATA 1.
https://en.wikipedia.org/wiki/Parallel_port
Aren't those output pins, normally? In an unidirectional configuration?
I mean, if a PC boots up in normal mode, aren't they set to output?
I vaguely recall that a GB cartridge dumper had a warning note that said the LPT port must be set to a specific mode.
As for the IRQ, no harm is done normally, I think. DOS software generally doesn't use IRQs for LPT ports.
OS/2 is one of the few exceptions and uses IRQs for printing, I believe.
Edit: Ah yes, I've checked the circuits.ini, so this makes sense.
Pin 10 is a status line (ACK) to read back the SNES pad data. Pin 2+3 are outputs.
So normal LPT mode seems fine, too, indeed.
[snes1]
clock = 2
reset = 3
data = 10
power = 7, 8, 9
Reply 3 of 3, by Jackhead
So my controller has ECP/EPP/Output only options I can also choose in ECP mode the DMA or disable it.
I tryed both ECP and EPP with different Port address like 278 and 378.
When i start a game with the sneskey command i got no controller shown ingame.
For example Keen4. So ECP is for Printer and Scanner and EPP for other stuff. But the question is what does sneskey use.
