First post, by 7F20
The GOG version has the Sierra exes and runs, but I can't seem to figure out how to get it running in DOSBox with the speech. It's obviously because the CD isn't technically there, but I know the speech files must be in the directory because I can get it running with SCUMMVM and speech. I want to use DOSBox because it makes it a lot easier to dial in the video mode on my setup.
Reply 1 of 8, by konc
Are you trying to use both speech + text? You cannot do this normally, it's only speech or only text. There is a patch for SCUMM to have both enabled and maybe this is why you have speech when using it, assuming my initial assumption was correct.
Reply 2 of 8, by 7F20
konc wrote on 2024-01-01, 10:11:
Sorry, no I am just trying to use speech alone. When I select speech in DOSBox, there is no speech. Also, it complains when I start the game that couldn't open an audio device, but I get the music fine (MT32).
Because of this, I was thinking maybe the reason I don't have speech in DOSBox is because the speech requires the CDROM disc to be in the drive. So to test this I mounted a folder as the CDROM. This made the warning about the audio device go away, but it did not result in speech.
Reply 3 of 8, by Shagittarius
7F20 wrote on 2024-01-01, 16:47:
Here are screenshots of my directories and my resource.cfg file:
The attachment 20240101_085418.jpg is no longer available
The attachment 20240101_092550.jpg is no longer available
The big files are the speech, its important to point your resource.cfg file where they are located, make sure you format it the same way I have in my resource fille.
The patchDir might be wrong, its hard to tell since I'm not sure where to check the replaced sfx, but I think it should actually be "Patchdir=.\;.\audiosfx"
Also make sure your in game config is set to "Speech" as below:
The attachment 20240101_090802.jpg is no longer available
Reply 4 of 8, by 7F20
Shagittarius wrote on 2024-01-01, 17:32:
Thanks for the screenshots. I guess I'm just not sure where to point the resource.cfg in my setup?
I have my game at c:\games\lb2, but I'm mounting c:\games as drive C: in DOSBox.
My resource files and everything are in the lb2 folder, and I have the audiosfx subfolder just like you do. I have the game set to Speech and it's not talking. Using Text works as expected. I tried mounting the Audiosfx folder as a CDROM drive and pointing the resource.cfg to that directory, but that doesn't seem to be the answer.
Reply 5 of 8, by Shagittarius
See what happens if you set the audio to audio=.\ or audio=.\lb2
try it both ways
Reply 6 of 8, by 7F20
Shagittarius wrote on 2024-01-01, 18:21:
try it both ways
success! this worked:
audio=.\
by the way, what is the program you are using for your directory? I tried to find something like midnight commander for DOS, but I couldn't figure anything out. Is that available anywhere?
Thanks again!
Reply 7 of 8, by Shagittarius
7F20 wrote on 2024-01-01, 18:32:
success! this worked: […]
try it both ways
audio=.\
Thanks again!
It's an old DOS program called ZDir. Here is a link: https://tipovers.com/zdir/
I usually rename it to just z.com so i just type z to get a directory. Make sure to put it in a directory in your system path so it will work everywhere.
Reply 8 of 8, by 7F20
Shagittarius wrote on 2024-01-01, 18:39:
try it both ways
audio=.\
Thanks again!
Oh yeah! I totally forgot about that program 🤣. I think I probably have a version of it on an old floppy somewhere too!
Thanks again!
