First post, by netdemon
Hello,
Can you recommend some games that run smoothly on Voodoo 1 ? Perhaps it would be a good idea to create such a list. Let's also assume that the Voodoo card is installed in a PC with a typical 1997 specs (for example, a CPU ranging from Pentium 100 to Pentium 200 MMX).
Reply 1 of 19, by Joseph_Joestar
Depends on what you mean by smoothly. Going by the modern definition of 60+ FPS with no drops, I doubt you'll find many games which fit that description. But if you're content with 30+ FPS with some occasional dips into the 20s, that is doable.
With that in mind, I found the following games to run adequately on a Voodoo 1:
  • Dark Forces 2: Jedi Knight
  • Descent 2
  • Final Fantasy 7
  • Mortal Kombat 4
  • Need for Speed 2 SE
  • Pandemonium!
  • Star Wars: Shadows of the Empire
  • Tomb Raider 1 & 2
  • Wipeout 2097
These are just the titles that I've personally tested. I'm sure there are more.
My retro builds
Reply 2 of 19, by Meatball
Beast Wars
Croc
Deathtrap Dungeon
Descent (3rd party Glide EXE)
Motoracer
NHL 98
Nightmare Creatures (Direct3D & 3rd party Glide EXE)
Quake GL
Resident Evil
Star Wars Rogue Squadron 3D
Turok
Reply 3 of 19, by Shponglefan
To echo Joseph_Joestar, it depends on your definition of smooth. For the time period, 30 FPS was generally considered smooth.
In addition to games already posted I'll add:
  • Blood
  • Fatal Racing (Whiplash)
  • Shadow Warrior
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 19, by maxtherabbit
3dfx Blood has a good framerate but idk if I could call it smooth with all the crashing
Reply 5 of 19, by DrAnthony
We might be able to add Tomb Raider, Battle zone, Forsaken, and MechWarrior 2 if around 30 fps average is considered smooth enough.
Reply 6 of 19, by Garrett W
All the games listed above are solid choices. I would also suggest running games at 512x384 on the Voodoo 1 on games that allow you to change the resolution, you get a really nice framerate boost and IQ is not that much worse compared to 640x480.
Reply 8 of 19, by leileilol
Battle Arena Toshinden
Cybergladiators
Interstate 76 Gold
long live PCem
Reply 9 of 19, by meljor
F1 '97
Nfs 3
Nfs 4
Nfs 5
F1 racing simulation
Screamer 2
Screamer Rallye
Testdrive 4
Testdrive 5
Toca 1
Toca 2
Breakneck
Colin mcrae Rallye
All run fine on a 233mmx with v1
Reply 10 of 19, by rasz_pl
Voodoo 1 had enough rasterization/fillrate to max out at around 30fps at 640x480. 60 fps required going all the way down to 320x240 and nobody wanted that compromise. Pretty much all Glide games created before Voodoo 2 will run at that 25-30 fps framerate on Voodoo 1 in either 640x480 or mentioned by Garret 512x384 so imo there is little need for lists. That was the big draw of 3dfx when it first released - buying it guaranteed not only prettier game, but also smooth framerate.
Even 1998 Unreal and 1999 Unreal Tournament do nice 25 fps on Voodoo 1 if you remove cpu bottleneck
3Dfx Voodoo Knockout - 6 Rounds Unreal Tournament - BlastFromThePast https://www.youtube.com/watch?v=DhAy7zSVVoA
1st Gen 3Dfx Voodoo Graphics - Unreal Tournament Benchmark - BlastFromThePast https://www.youtube.com/watch?v=uMGwJxCriHw
Reply 11 of 19, by netdemon
Thanks for your tips.
I think, that 24 frames per second can still be considered smooth, taking into account how "smooth game" was perceived in those times 😀
Reply 12 of 19, by analog_programmer
netdemon wrote on 2024-01-03, 14:55:
Yep, back in time (mid '90s to 2k) 24 to 30 fps was considered smooth PC gameplay.
Can you summarize the game list in your first post for convenience?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 13 of 19, by chinny22
leileilol wrote on 2024-01-02, 01:09:
Interstate 76 Gold
I76 deserves special mention as apparently it doesn't run smoothly on later cards (at least that's what LGR said on one of his videos, haven't tried it out myself yet
Reply 14 of 19, by midicollector
I’m actually not totally sure how common or rare reducing resolution to increase framerate was. The common idea today is that it wasn’t done, but personally I used to reduce resolution to increase framerate at the time. Maybe I was the only one doing it, it’d be interesting to find out how common or rare it was. At the time, I probably would have reduced to 320x240 to get better performance, but I can definitely see other people not doing that. I wonder how common or rare it was overall.
Reply 15 of 19, by rasz_pl
Lowering to 512x384 already usually got you over 40fps, something unheard of on PC before 3dfx.
Reply 16 of 19, by chinny22
midicollector wrote on 2024-01-04, 04:21:
I'd think it was pretty common. Definitely was in dos days, Rise of the Triad even told you to upgrade if you went the slowest resolution.
302026
However back in the late 90's early 2000's when hardware obsolescence was much faster is wasn't uncommon to have to reduce the resolution, luckily CRT's hide it a bit better as well.
Reply 17 of 19, by leileilol
Unreal defaulted to 512x384 on initial release for a reason 😀
512x384's also the resolution of some 3dfx arcade games that have seen ports over to Windows that actually look worse on 640x480, like NFL Blitz
Lowering 3D cards down to 320x240 was mainly a Virge/Rage/PowerVR thing more out of fill rate's sake, but became less practical by the second wave of 3d cards (though early laptop GPUs would take this turn next). 3dfx cards couldn't use that res until Banshee
long live PCem
Reply 19 of 19, by weilun777
netdemon wrote on 2024-01-01, 15:26:
Hello,
https://www.youtube.com/watch?v=8YgKED3E7TA&t=1382s
NBA LIVE 2000
