First post, by Sphere478
I have a Orange pc 530 coming and want to prepare for maxing it out
We have another thread for the 620 variant
Trying to use a K6-2+/3+ in an OrangePC 620 PC compatibility card.
Mine I fear may be more of a challenge.
I want to max out its specs.
For sure 400-500mhz k6-3+
Vram upgrade, would be great if possible, I can swap chips,
Maxing out ram is a given,
And I think I’m gonna need Jan’s help once again for the bios 😀
But one of the challenging bits, the cable is missing.
Anyone have a link for that connector, and/or a pinout? That in of its self may be a show stopper. 🙁
    298.78 KiB
    252.5 KiB
    229.99 KiB
    245.64 KiB
    33.29 KiB
Sphere's PCB projects.
Reply 1 of 32, by AlessandroB
hi, i just to ask some information, potentially i can have a 420 version but i have no idea if it is compatible with a G4 Quicksilver and i can’t find any information… can you help me please?
Reply 2 of 32, by BitWrangler
Where does it all end though, if you put an orange in your apple, ppl will want a tangerine in their apricot or a blackberry in their raspberry, and we've just gone down the turducken rabbithole with fruit salad.
Reply 3 of 32, by Sphere478
BitWrangler wrote on 2024-01-01, 20:18:
I’m gald I wasn’t drinking a soda. 🤣
AlessandroB wrote on 2024-01-01, 19:49:
🤷‍♂️ I would guess it would be compatible.
Do you have the cable for it by chance?
Reply 4 of 32, by AlessandroB
Sphere478 wrote on 2024-01-02, 00:06:
I’m gald I wasn’t drinking a soda. 🤣 […]
yes the cable is provided, but i not yet the card because i have zero knowledge about apple powerpc world, i absolutely do not know if it work or not in a compter much more younger than the card. Do you know something more?
Reply 5 of 32, by Sphere478
AlessandroB wrote on 2024-01-02, 00:43:
I believe it probably has more to do with the operating system on the mac. As long as it fits in the slot and the operating system is supported I would think it would work, but I am not sure.
Can you provide a pinout diagram of the cable? I wish to make my own.
Reply 6 of 32, by Sphere478
I had a thought.
It might be possible to make a pcb that bolts onto that port with screws and offers a breakout of the connections in a way that is more compact than the oem cable. Soldered on pins could tap the connections
Reply 7 of 32, by Sphere478
By the way, am I correct that the card takes only EDO DIMMS? Not SDRAM?
If so, should not the max addressable be 256mb? Or 512mb? I see specs only list up to 128. I intend to try to beat 128 if possible.
Reply 8 of 32, by AlessandroB
Sphere478 wrote on 2024-01-02, 01:41:
My computer came out with OS 9.2.x. I haven't found any information on whether the control software for these cards (the one I could get is a 420) is compatible with this OS. If you help me understand it I could take the board and once I take it I could find the pinout of the cable whip you need
Reply 9 of 32, by Sphere478
I’m new to them myself, Try it and see.
Reply 10 of 32, by Sphere478
Okay, what’s max possible ram?
256mb edo dimm?
I assume sd isn’t supported?
5v only?🤔
    149.02 KiB
Reply 11 of 32, by Sphere478
https://wiki.preterhuman.net/OrangePC_530
According to this 5v ram modules which makes sense.
But says max 128mb which I want to confirm.
What chipset is under the sticker?
What is max supported by the chipset??
Reply 12 of 32, by PC Hoarder Patrol
Says 128MB on the archived spec page...
"Model 530: 7"card; PCI Interface: 64-bit Pentium design for PCI based Macintosh; 2 MB video DRAM; user expandable RAM up to 128 MB (includes internal video cable for use in "All-In-One" 5400/5500 Macintoshes)
Your choice of processors for OrangePC 530:
Intel Pentium MMX 200 and 233 MHz; Intel Pentium classic 100-200 MHz; Cyrix 6x86 PR166+. Pentium Pro and Pentium II processors are not compatible.
Memory Specifications:
Two DIMM sockets on Models 550 and 540, one DIMM socket on Model 530; configurations allow any combination of 8, 16, 32, 64 or 128 MB Macintosh compatible; 2K refresh, non-composite, Fast-Page Mode, 70ns or faster, 5 volt DIMM, Max. 1" height.
Reply 13 of 32, by Sphere478
The model I have seems to only have jumper settings listing up to 200 mhz
As we know though, the 1.5x and 2x can be handy for later processors.
However there seems to be a total lack of voltage options on the board. Leading me to think that my particular one might be single plane.
Peeling the sticker back that says 166 cyrix I can see it does say socket 7 however we have seen many a single plane socket 7 board.
There is a very simple linear regulator on the back of the pcb, I’m going to guess that these old macs had 5v pci standard and that lone regulator on the card is the 3.3v supply meaning that this card really doesn’t support pentium mmx.
A k6-233 ANR might be happy here but that might pull a bit of power for that linear reg.
Another fun thing I noticed was the presence of a mr bios sticker. Not sure where that leaves us with getting Jan’s help adding k6-+ support 🙁
Yes, not all hope is lost for mmx and above. A interposer should be able to be used here.
Hopefully I’m not missing something, as the ad clearly says supports mmx maybe it isn’t a 3.3v reg but a 3v one trying to make all sub 233mhz chips happy? Or maybe I’m wrong about 3.3v being present on mac pci? But if so where is the voltage adjustment jumper block?
Anyway,
I’m noting a connector near the bottom of the card, is that for a missing vga connector? How did these transmit video to the mac?
Reply 14 of 32, by Sphere478
Pics
    829.96 KiB
    818.37 KiB
Reply 15 of 32, by Sphere478
https://en.m.wikipedia.org/wiki/List_of_VIA_chipsets
According to this,
The chipset supports 512mb of ram.
So if they ran the address lines for it, It may actually max out at 256 or 512mb
I’m going to guess probably not 512mb with only a single socket though. Probably 128 or 256 is where I’ll end up.
Reply 16 of 32, by Sphere478
I did some more investigating today.
Turns out the unit is indeed a dual plane socket. The regulator at the back seems to step 3.3v (which I assume comes from the pci slot) down to 2.8v
Again, don’t see any jumpers to change it,
The two planes in the socket are indeed separated verified with ohm meter.
Looks like when a single plane cpu is installed it probably just shorts the 2.8v to 3.3 and calls it a day.
Anyway, this means for any fun cpus I have to either hack the linear regulator to supply a lower voltage, (if it can do that at all…) or use a interposer.
The logical first choice that comes to mind for 2.8v would be a pentium 233 mmx.
However, the socket 5/7 ecosystem was quite diverse,
Rise made a 366 which I believe was 2.8v and later ones that were 2.2v or 2.0v however if memory serves, it was a PR rating, actual clock was 250mhz? Its performance may be comparable to a 233 mmx. (Maybe)
Winchip had a 266 mhz part that ran at 3.3v it however would probably be slower than a 233mmx
K6 chips had the 233mhz ANR that may work, but again, the 233 mmx might be as fast, certainly a easier pick to find. And from the looks of it, this orange pc would undervolt a ANR by about 0.3v
Cyrix however….
They made chips with 2.9v ratings forever it seems.. all the way to 366gp which is a PR rating. They had a 4x multiplier that was able to be selected, and at 66mhz fsb would be a 266mhz part. That chip would probably be a bit more snappy at most things than a 233mmx. But perhaps not wiping the board.
I’m going to say a overclocked 366gp is certainly worth looking into for those reading this looking to upgrade their own.
I however, will likely use a interposer or modify this card to get down to 2.0-2.2v where the king is the k6-3+ 400 (@66fsb)
Edit:
Rise cpu voltage and multiplier settings
Re: Cyrix 400gp multiplier settings
Idt Winchip 1, 2, 2a and 2b differences
So to get 4x bf2 needs a pull up resistor, the orange pc only seems to have settings for bf0,bf1. An easy socket mod to be sure.
Reply 17 of 32, by Sphere478
At this point I think I am basically dead in the water on this project.
Without the cord this is nothing more than a curious brick.
If anyone can help mapping the pinout of the cord, that would open up some possibilities.
If anyone has a cord, that would be even better,
I kind of expect that I am going to end up making a cord.
Baby steps.
Reply 18 of 32, by Sphere478
Db-62 looks a little familiar
    40.53 KiB
Reply 19 of 32, by Sphere478
Looks like it supports 4mb of memory, swapping out those memory chips should be easy enough. If the address lines are there, and they come in 2mb
http://www.bitsavers.org/components/s3/DB018- … rator_Jul95.pdf
If someone with a PC can rehost that pdf here that would be awesome.
    36.91 KiB
