First post, by romtos
Is there a XT IDE card variant with a (fast/16550) RS232 combined on one PCB? I have 2 systems with only 3 slots, and with VGA and Token Ring, I’m running out of slots.
Reply 1 of 3, by keropi
The original XT-IDE REV2 board has optional serial port capabilities: https://minuszerodegrees.net/xtide/rev_2/XT-I … -%20general.htm
I am not aware of another variant that offers this... be sure to read the "Optional serial port (optional 'UART')" section as it explains what the serial port does and does not.
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 2 of 3, by romtos
keropi wrote on 2024-01-02, 19:40:
Thanks a lot, I’m fine with both restrictions (4x faster than 'advertised' baud rate, and only RTS/CTS handshake)
Reply 3 of 3, by Jo22
Hi, some ISA modems and multi i/o cards have an 16450 in DIL/DIL form.
It can be substituted by, say, an 16550AFN chip.
I did this modification with an 286 PC which had an 16450 on-board. I've added a socket and installed the 16550AFN.
Btw, if you're trying to use it on Windows 3.1, a replacement serial port driver is recommended. Like the Cybercom driver.
The FiFo must be enabled in the system.ini to take advantage of the buffer.
More information on http://stephan.win31.de/w31mm_e1.htm
WfW 3.11 has an updated serial port driver and works good without it, too.
Good luck 🙂
PS: About the XTIDE AUX port.. Becareful it misses DTR and DSR. And the Ring Indicator RI. Edit: And DCD. 🙄
The first two were famous handshaking lines used by some DOS applications (rather than RTS/CTS).
Anyway, just saying. With a soldering iron, the missing pins for DE9 available on the 16550 could be wired manually to the pin header by jumper wires.
Edit: The use of DSR/DTR was more common in the terminal/mainframe sector, maybe.
If you're running old commercial communications software, that might be good to know.
Gamers used RTS/CTS, rather, I guess? 🤔
Edit: This one is helpful: https://stackoverflow.com/questions/957337/wh … ts-flow-control
DSR/DTR was popular up until the mid-80s.
Together with RTS/CTS they ensured that terminal-host and modem-terminal weren't overwhelmed by a flood of data.
A terminal of the time also could have been a teletype with a punch card/punch stripe reader/writer.
That way, large amounts of data from the terminal side could have overwhelmed the host computer.
That's why both pairs should be part of a modem cable or null-modrm cable, I suppose.
