First post, by zwrr
Hello, I recently got an Octek HIPPO-15 motherboard that looks perfect, but I had a strange problem testing it.
Hardware used in the test:
CPU: AMD X5-133ADZ and Intel 80486DX2-66
MainBoard: Octek HIPPO-15 (256K L2 Cache installed)
Memory: 16MB (8MBx2 60ns)
Graphics: S3 Virge/DX 4MB
I tested with PhilsComputerLab Bench and when I was using the 486DX2-66, everything worked fine, and Doom, Quake, etc. ran many times without any problems.
But after changing to X5-133, the system often freezes, which can happen at any time, with no regularity.
It can be determined that the X5-133 and the memory are good, they work perfectly on another BEK-P407.
I tried a couple of things:
1. Disable L2 caching
2. Replace the graphics card, GD-5422, S3 Trio64V+, Millennium II
3. Replace the PSU
4. Refresh multiple versions of the BIOS
But the problem remains.
Considering the power difference between the two CPUs, I wonder if it has something to do with the capacitors around the CPU, should I replace them?
1.11 MiB
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
486DX4-100EW, VI15G, 32MB, ARK1000VL, ES1868F
5x86-120GP, HIPPO-15, 32MB, Riva128, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
Reply 1 of 6, by mockingbird
Loosen your memory timings... Set both memory and cache timings to the lowest setting possible. If the freezing goes away, then the issue is that your timings are too tight.
(Decommissioned:)
Reply 2 of 6, by zwrr
mockingbird wrote on 2024-01-05, 03:13:
Thank you for your answer, I have a question,
The 486DX2-66 and X5-133 use the same 33MHz FSB, do they need to have different memory and cache settings?
Reply 3 of 6, by watson
The problem most likely has something to do with the VRM becuase the DX2-66 runs straight off the 5V rail provided by the PSU, and that's why it works.
Normally, I would advise you to change the caps in this situation, but they seem to be good brands (Rubycon and Elna judging by the vents).
I am certainly not a fan of recapping without proper diagnostics, but it might be worth a shot. Otherwise, you would need an oscilloscope to measure the 3.3 V output under load.
Reply 4 of 6, by mockingbird
zwrr wrote on 2024-01-05, 03:45:
I don't fully understand the mechanism of why it would matter, but try it anyways and see if it solves the issue. I had a similar issue and fixed it this way. I used Doom as the ultimate stability tester... I could play for a while and then it would lock up. Loosening my memory timings fixed it.
(Decommissioned:)
Reply 5 of 6, by CoffeeOne
mockingbird wrote on 2024-01-05, 13:15:
The higher internal speed (133 vs 66) and the doubled L1 cache will create more accesses to the L2 cache, so it is possible.
But I agree it is the same 33MHz bus ..... So maybe there are also instabilites with 66, just the likelihood is smaller.
Reply 6 of 6, by zwrr
I fixed it by replacing the CPU socket and now everything is fine.
Need help replacing the pins of the Socket3 socket
I get the impression that the CPU socket contacts are not in good contact due to rust, which makes it look normal under DX2-66 because of the 5V voltage and lower data transfer speed, but when changed to X5-133, the 3.45V voltage and double the data transmission make it unstable.
