First post, by zuldan
About to finish my 386 build. Just need to configure the LED Speed 40/25. I've had a look at https://www.minuszerodegrees.net/led_speed_di … eed_display.htm but can't find a PCB that matches. Is it just a process of elimination to figure out the settings? Can I assume top row is turbo on and bottom is turbo off (or visa versa). Any tips would be greatly appreciated 😀 It's currently showing "90".
Reply 1 of 5, by BitWrangler
I think it might be labelled in the conventional manner for 7 segment LEDs, thus...
https://www.jameco.com/Jameco/workshop/TechTi … t-displays.html
With high and low rows, with each digit having it's setting for each segment like A1 A2, B1 B2 etc down the block.
Reply 2 of 5, by wbahnassi
My recommendation is while you're figuring it out, do NOT remove all jumpers. Keep all jumpers and just focus on one or two at a time. It seems this is one of those turbo displays that shares one resistor for all LEDs, which means it is calibrated to give decent light when typical digits are displayed. If you remove all jumpers then too much current will go through the LED that you're isolating, and it will burn.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 3 of 5, by zuldan
BitWrangler wrote on 2024-01-07, 06:39:
Fantastic, I got it configured. Thank you!
Reply 4 of 5, by zuldan
wbahnassi wrote on 2024-01-07, 07:09:
Thank you for the tip!
Reply 5 of 5, by zuldan
Ok silly questions...
Question 1: I push the turbo button (wires connected to "P" and "L" on the PCB) but the LED display doesn't change. Does the LED PCB need to be connected to the motherboard? As in, the motherboard must confirm that it has changed the turbo mode?
Question 2: There is only 1 wire that goes to the motherboard. It's labeled "S" on the PCB. The motherboard obviously has 2 pin header for the turbo switch. How is that going to work? Does only 1 pin need to be connected?
Apologies for the silly questions, it's my first time configuring one of these.
