First post, by Scythifuge
- Oldbie
Greetings!
Back in 1999, I got a Gateway Performance P3 450 with an EV910 19" monitor. It was the last prebuilt PC I ever had. A year or two later, I built my first PC, an AMD K62-350, and bought a Philips 19" as my main monitor. I did use the Gateway monitor for many hours a day until I got the Philips. I ended up giving the EV910 to a friend of mine, though I don't know how often he used it, but most certainly not as heavy as my use. He recently gave it back as he had it in a closet and I have been trying to get a working 19" monitor. However, the picture is so dim at 100% brightness that it is unusable. He hadn't used it in years, so it seems to have prematurely lost its brightness. I know it could be bad caps, but it could also be something else.
I came across this link where someone claims to have bypassed the brightness issue using a 120v capable VGA switch box from IOgear, but the model isn't listed. He claimed that hooking up a dim display to the switcher brightened up his monitor enough to be usable again.
https://www.fixya.com/support/t1868517-gatewa … 120_crt_monitor
Has anyone experienced this or have any information on this and why it would work? And if so, can recommend a "120v capable" VGA switcher? I have actually been looking into switchers since I have both a Windows accelerator and a video card for DOS on the way (both Diamond cards.)
Thanks!
Scythifuge
