Pentium4 and SSD
First post, by AlessandroB
I planned to put SCSI disks inside 3 computers in my collection i.e. 486/Pentium/Pentium2/3. In the Pentium4 (which is supposed to be an overkill machine for DOS and Win98) I was thinking of putting an SSD. Since it only has the IDE controller integrated (it's a socket 478) I can choose whether to put an IDE-Sata converter or a PCI sata controller with the bios etc... what do you recommend considering that I would use a 120GB SSD that I no longer use? I have a cheap anonymous pci-sata controller and when installing win98 it always gives me blue screens so I thought I'd use something more professional than my cheap Chinese controller.
Reply 1 of 25, by mockingbird
I recommend the IDE to SATA converter, which is what I use. Use something with the Marvell chip and don't forget to enable UDMA in Windows 98.
(Decommissioned:)
Reply 2 of 25, by The Serpent Rider
Keep in mind that anything you put in PCI will share 133Mb/s bus with every other card. Integrated PATA, SATA, LAN and USB on P4 motherboards are connected directly to a south bridge proprietary bus with better bandwidth (266Mb/s or higher).
Reply 3 of 25, by AlessandroB
The Serpent Rider wrote on 2024-01-11, 17:36:
yes, but "consecutivde transfer" is not the primary goal, is a huge fast acces, even if i do 50 ms/s on ssd the difference between a regular hard disk is massive. the question is: use a SSD is better via the integrated 133udma ide channel ora using a more modernd SATA chip integrated in some fastrack PCI card?
Reply 4 of 25, by Repo Man11
Here's my PCChips M930, SiS 645, DDR, and a 2.8 533 P4 with an inexpensive SSD using the onboard IDE with an adapter. This is lightning fast with Windows 98.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 5 of 25, by AlessandroB
ok, let's start with the cheap ide to sata, can you post me an example of the models i need to buy? tnks
Reply 6 of 25, by Repo Man11
I use one of these with my M930 (and a couple of other boards). I like them because they plug into the IDE socket for a tidy installation (using a SATA cable to the drive instead of IDE) and they have worked fine for me. Usually sold under the name StarTech.
Reply 7 of 25, by chinny22
I have most success with ones that has the jumper that lets you pick between master/slave/CS
Reply 8 of 25, by AlessandroB
Repo Man11 wrote on 2024-01-11, 22:14:
i prefer the one that fit on tge hard disk because 1) seems that one ide channel must be connected to only one sata 2)you need to provide power to the adapter and convert molex to sata on the drive, adding cable and complexity inside the case
Reply 9 of 25, by The Serpent Rider
More reason to use native IDE, to improve latency.
Depends on south bridge PATA performance and how much external SATA can hog PCI bus for itself. On the picture above you can see that SIS south bridge is nowhere near the limit of UDMA133.
Reply 10 of 25, by AlessandroB
Arrived Tday, win98 installed without issue on a Crucial SSD 120GB. My question is: this Pentium4 now think to have some sort of IDE drive but... what about Trim? What about all the management that SSDs need?
Marvell chip
Reply 11 of 25, by Ryccardo
AlessandroB wrote on 2024-01-17, 20:59:
First, get some relatively modern Linux compatible with that computer - Devuan does have a text-mode "minimal live" that's CD sized but I bet it's not the last one standing;
2: use that to create the partitions (fdisk/cfdisk/etc, then you can even format them with mkfs.vfat), that way they'll be normally rounded to a whole megabyte which more than satisfies 4k alignment;
(this is fundamentally incompatible with DOS style alignment to cylinders, I think it's not a problem with "32 bit disk access" native drivers except possibly for some disk utilities)
1: every now and then, boot it up again, mount the partition (for example: mount /dev/sda1 /mnt) then trim it (fstrim -v /mnt) 😀
Reply 12 of 25, by Joseph_Joestar
Trim is unnecessary for modern Crucial SSDs. See here.
Just leave the computer idling at the BIOS overnight from time to time, and you're good.
My retro stuff
Reply 13 of 25, by AlessandroB
Joseph_Joestar wrote on 2024-01-17, 21:16:
you mean "inside the bios"? pressing F1 at start?
Reply 14 of 25, by Joseph_Joestar
AlessandroB wrote on 2024-01-17, 21:36:
Yeah, just enter the BIOS and leave it there.
As long as there is no disk activity, the SSD will take care of itself.
My retro stuff
Reply 15 of 25, by Trashbytes
Joseph_Joestar wrote on 2024-01-17, 21:46:
Its not just Crucial that does this, most decent modern SSDs do this, not sure if the cheap ones using older controllers have this function.
Not sure why people get so worried about Trim support.
IIRC Intel has a DOS/Win utility that you can run to manually start Trim and there are other tools that can also do this such as the one from RLowe.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 16 of 25, by darry
If it's a Startech PATA2SATA3, it likely has a Sunplus SPIF223A (or maybe that has changed). My experience with it and a few alternatives is chronicled here
Re: Small capacity SSD PATA/SATA benchmarks
Reply 17 of 25, by Ryccardo
As I understand it, that's pure marketing!
Yes, automatic garbage collection (low level defrag + [compression if supported]) is usually real, but it doesn't change the fact that the process strongly benefits from knowing which sectors are free, which is only really effectively* done with trim - there's just no substitute unless they made the nand controller aware of the major filesystems and assume everyone will be using them that way# 🙁
* A controller with hardware compression MIGHT "understand" if you set all free space to FF or 00 or whatever, but that's not how FAT normally works 😀
# Not unprecedented, see the SMR scandals of 2020…
Reply 19 of 25, by kingcake
Garbage collection != TRIM command
