First post, by informatyk
Hello, I've got motherboard DFI CA64-TC https://theretroweb.com/motherboards/s/dfi-ca64-tc which does not beep on startup and does not boot. I tried with and without RAM, GPU but still the same, after powering on switch fans keeps running at 100%. FSB was set to AUTO. I cleard the CMOS. It should at least beep right? How to check if it is dead?
https://download.marpio.net IE4 compatible retro software download site
Reply 1 of 8, by ciornyi
To get it find out you have to have some working spare parts and post card analyzer . Anyway it might be corrupted bios or old version which doesn't support specific cpu
DOS/95: PII266/128mb/AWE64/TNT
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/2GB/SB X-fi/HD6850
Reply 2 of 8, by informatyk
I've got it with CPU and FAN installed so the CPU (Celeron 1000) must be compatible. POST card is good advice so I will buy one.
Reply 4 of 8, by Nexxen
informatyk wrote on 2024-01-16, 14:56:
https://www.aliexpress.com/item/1005004768305705.html?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 5 of 8, by ciornyi
Nexxen wrote on 2024-01-16, 15:03:
Yeah i got exact the same .
Reply 6 of 8, by Nexxen
ciornyi wrote on 2024-01-16, 17:25:
It's a good investment. I used it so much it paid for itself a long time ago.
Reply 7 of 8, by chrismeyer6
Stupid question have you check to see if the bios battery is dead. I've had quite a few boards act dead untill I changed out a dead or missing bios battery.
Reply 8 of 8, by informatyk
I probably found the problem, capacitors are swollen.
