First post, by Eimer
Onboard graphics in Compaq 386S.
Looking for Windows 3.x Drivers.
any help is appreciated!
The attachment image.png is no longer available
Reply 1 of 4, by mkarcher
That's a custom ASIC ordered by Compaq and produced by Motorola. The Compaq part number of that custom chip is 121927-002. It happens that the same chip is mounted on the Compaq Advanced VGA.
The VESA driver for the card can be found at https://archive.org/details/CPQVESA .
Compaq SoftPAQ SP2225 contains a Windows 95 driver (english). I couldn't find a SoftPAQ with an "Advanced VGA" or "AVGA" driver for Windows 3.1 in the list at https://www.rigacci.org/comp/aero/doc/allfiles.txt . As I didn't try to search any further, so you might still find a driver elsewhere. As the Compaq AVGA is a quite old Compaq VGA implementation, there surely will be some Windows 3.1 driver for it.
Reply 2 of 4, by PC Hoarder Patrol
Eimer wrote on 2024-01-15, 19:35:
Onboard graphics in Compaq 386S. Looking for Windows 3.x Drivers. […]
Try these...
The attachment SP1241.exe is no longer available
The attachment SP1241.txt is no longer available
Reply 3 of 4, by PC Hoarder Patrol
Knew I had a later set somewhere...try these instead
The attachment SP1734.exe is no longer available
The attachment SP1734.txt is no longer available
Reply 4 of 4, by Eimer
thanks will try!
