First post, by dccs
So this game crashes on startup with dgVoodoo2, no matter what settings I use on it. Works with 3DAnalyze, but it's DX8 and uses its own renderer instead of dgVoodoo's one, however I want DX11/12 to be able to use tools like ReShade with the game. Not even crosire's d3d8to9 wrapper works on it. Could dgVoodoo2 be updated to work with this game?
Reply 1 of 9, by Dege
Yes, ok I made a workaround and now it works with dgVoodoo. I only tried the US version of the game with patch 1.1 but considering what the problem is, it should work for all other versions too.
Reply 2 of 9, by dccs
Dege wrote on 2024-01-23, 17:26:
Thanks, will wait for the update then. And yes, I'm running v1.1 as well.
Reply 4 of 9, by dccs
Dege wrote on 2024-01-28, 11:15:
Meanwhile I released an update containing the fix:
Re: dgVodooo 2.8.x and related WIP versions
It works well, but there are some texture bugs, like in the sky, not sure if this is caused by dgVoodoo or not. I remember 3DAnalyze specifically has a "LOTR texture fix" box for Fellowship, so dgVoodoo might be able to fix it as well.
Reply 5 of 9, by Dege
I don't have such bugs. Everything looks fine:
I just installed the US version, patched to 1.1 and copied dg D3D8, I'm not using anything else.
Reply 6 of 9, by dccs
That's definitely weird because I've never had this issue on any other game I've used dgVoodoo on. Maybe there is some setting I'm configuring wrong...
Reply 7 of 9, by dccs
Found the problem, forcing AF causes the issue... Which sucks a lot, since without any texture filtering, the game looks way too blurry.
PS: Forcing AF at the driver level works just fine however.. thanks for the fix anyway.
Reply 8 of 9, by Dege
You can also enable option 'Force filter only if not point sampled'.
Reply 9 of 9, by dccs
Dege wrote on 2024-01-29, 19:28:
Yeah that works as well, thanks.
