First post, by pentiumspeed
Subject says all.
I even tried to uninstall and delete the driver, and downloaded correct one from dell for this model, installed it. Initially worked after this, one reboot later, still works, then second reboot later, back to same error.
The usual online solutions was remove, or reinstall. The bios shows this GTX 1650 is present, with this error, the GPU-Z only shows intel iGPU as present.
Battery is healthy as I checked the mAh capacity using a hw monitor from CPU-Z website as part of my diagnostic checks.
I have very limited access and time with this notebook since the person needs it for his study, will be back again on Friday at my work.
Do you think the GPU is dying?
I'll try to reinstall the drivers for Dell but this is very tedious and device manager shows good status.
Cheers,
Great Northern aka Canada.
