First post, by tobiasrieper
Hey guys hopefully someone can help me, I've seen similar threads on the matter but can't seem to find a resolution. No matter what I've tried the 3dfx splash screen will not show when using Glide API games, Tomb Raider (glide version), Deus Ex, Unreal, Heretic 2. This is in Windows 98 SE.
I used the original drivers for the Voodoo 3 V.1.00.00 as well as the latest drivers and others.
In 3dfx tools I made sure disable splash screen was unchecked and also made sure the registry entry value for FX_GLIDE_NO_SPLASH was 0, blank or the key completely removed.
Any ideas? I know it seeks trivial but it's driving me nuts.
Reply 1 of 9, by Meatball
Heretic II is an OpenGL game. Deus Ex and Unreal share the same engine, and I've never seen the splash screen show up with those games. Tomb Raider; I've only seen it with a Voodoo 1, but perhaps it would show up with a Voodoo 2?
Try playing Turok - you will see the splash screen on that game no matter the 3dfx card - if not, then you have problems.
Reply 2 of 9, by Joseph_Joestar
Meatball wrote on 2024-01-18, 15:08:
Been a while since I last tried these games on a Voodoo card, but I think the splash screen does show up in GLQuake if you use MiniGL instead of the standard OpenGL renderer.
EDIT - splash screen works in GLQuake when using MiniGL 1.48 or older.
Reply 3 of 9, by Jasin Natael
There are a quite a few later Glide games that don't show the splash screen.
Reply 4 of 9, by leileilol
All UnrealEngine games explicitly bypass the splash screen for GlideDrv. idTech 2 and 3 games also bypass the splash screen. For Direct3D games there's not a splash screen at all.
long live PCem
Reply 5 of 9, by Shadzilla
If you have GTA that should show the splash screen, it does for me in DOS at least.
Reply 6 of 9, by tobiasrieper
Thanks for your input everybody. The above games I'm making sure they all run in Glide. Ahh right about the Unreal that makes sense. Heretic II runs in glide nicely. As long as there's nout wrong with the Voodoo. I have not got Turok unfortunately 🙁 it's pretty rare on ebay PC version.
Reply 7 of 9, by tobiasrieper
Loaded up Turok and it works. 3dfx Splash Screen yay! Now see if I can enable it for unreal games.....
Reply 8 of 9, by Joseph_Joestar
I just tried it with GLQuake on my Voodoo 3 and it does work, but you need to use MiniGL 1.48 or older.
It seems that newer versions of MiniGL remove the 3DFX splash screen in that game.
Reply 9 of 9, by tobiasrieper
I see thanks! I'll try those older drivers. I'm using WickedGL at the mo.
