First post, by Bobolaf
Probably a silly question but, is accessing an NVME disk on a earlier OS like Windows 98 possible from older hardware? I am not talking booting but rather simply accessing. Thanks.
Reply 2 of 4, by Trashbytes
If the NVME doesn't work under 98 you may want to try a SATA based NVME, 98 is fine with sata devices but may have issues with modern NVME controllers that are expecting Win10+
Reply 3 of 4, by Ryccardo
For whatever it's worth (not much for 9x, it's an EFI-first Ivy Bridge motherboard) I have a SZMZ B75MS (=Jingsha B75A) which, according to uefitool, does have a NVME to Int13 driver 😀
Not tried it though, and I suspect it will have limitations (1 namespace only and the like)
The Samsung 850 is also famous for having such an option ROM, I think…
Bobolaf wrote on 2024-01-20, 07:38:
The latter is generally easier than the former only because most contemporary OSes have NVME drivers, but in this case it'll be easier, at least on paper, to get bootable-grade support and then use the generic int13 interface… or an active converter (with probably the same limitations) and the generic USB Mass Storage Class interface 😀
BTW if it's NVME it has nothing to do with AHCI unless some conversion logic is involved, there are a few rare "AHCI" SSDs that look like NVME ones (they're both PCI Express after all) but "simulate" a SATA controller, and then as mentioned there are mSATA/M2.SATA ones that need an external disk interface like a normal HDD 😀
Reply 4 of 4, by matze79
It works even with oldest PCIe Systems.
You just need a PCI Network Card with ROM Socket, a ROM and this Project.
https://github.com/Manawyrm/nvme-int13h-optionrom
Or if you have Award BIOS ROM it could be injected as PCI Option ROM.
Then you can boot even a P4 or a A64 from NVME.
