Siedler 2/Setllers 2
First post, by Choey
i cant start the game S2. When i run S2.EXE it just shows me a blank, black screen. i have a TFT and i managed to run it without DOSBOX, but with a few problems (screen size doesnt fit etc.)
Anyone here to tell me the right settings?
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
did you mount your siedler 2 cdrom ?
Water flows down the stream
Reply 2 of 8, by Choey
yep. problem is not the CDRom. You dont even need it when playing the original game (without gold ed.)
i intalled UniVBE and got an error msg:
outer main loop: selected screen mode not avail!!
Reply 3 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
ah dosbox only support 800x600 and 640x480
not 1024x768
Reply 4 of 8, by HunterZ
Try using a CVS build of DOSBox. See the development forum for info.
Reply 5 of 8, by Choey
but S2 doesnt start on 1024x786 but on 640x480? and what do i do to fix it?
Reply 6 of 8, by Choey
problem solved, thx.
Reply 7 of 8, by HunterZ
How did you solve it? Others may have the same problem and come here looking for answers.
Reply 8 of 8, by Choey
oh, it was with the cvs at http://ykhwong.x-y.net/page.htm
and i installed a patch on S2 wich crushed an image. i needet to copy it. so nothing dosbox related there.
C:\Siedler\GFX\PICS\SETUP997.LBM was missing. i just copied the SETUP998.LBM and renamed it.
But it is SLOW. im running a 2.4 Ghz machine here, and it is slower as it was on my 386 machine i had a few years ago. (i would use it now, but i cant afford to maintain such an old computer...)
Any ideas how i can get it faster?
