Crash with NV D3D12
First post, by mitradis
Background: Yesterday I updated the BIOS and video card driver. Im a IT specialist and I know how to do it all (vga driver must updating through DDU, and after bios updating need do full reset). I haven’t updated them for a very long time because I have all updates disabled. I only do updates manually, when I think it's necessary. After the update, I did not notice any abnormalities in the operation of the PC and its programs or games. I managed to play a lot of old games, most of which are with dgVoodoo. I have 1060 6gb (), and B660 DS3H DDR4 (rev. 1.0). Previous bios version F3 (https://www.gigabyte.ru/products/page/mb/B660 … port#support-dl) now F28. Driver version now 551.23 (Previous version i installed ~one year later). I don’t want to reinstall anything and return it back because I still don't understand the reason. Because I don't see any problems with other games running in OutputAPI=d3d12 or OS or programs.
But I decided to launch NFS Underground 2 and play a little. But at the first race at the start I got a CTD. I started to figure it out and of course the first thing I did was turn off the wrapper. Everything was fine. I started studying what wrapper settings do this. And stopped at OutputAPI. If i set OutputAPI=d3d12 I will get CTD. I haven't encountered this before updating. I don't know if this is related to the driver or BIOS update.
https://youtu.be/rGImZCsk514
(Exception Details: A thread attempted to read or write data to a virtual address to which it does not have appropriate access.)
But the most interesting thing: i try record video by OBS Studio but when i run record NO CTD! And I had to record it from my phone...
i check this on dgVoodoo2_79_3 too and have same behaviour.
UPD: same problem with R6 Raven Shield.
Tested games (OutputAPI=d3d12):
Age of Empires III
Black Hawk Down
Blitzkrieg 2
Blitzkrieg
Colin McRae 2005
Dawn of War
FarCry
Flashpoint
FlatOut
Global Operations
Hot Pursuit 2
Mafia
Perimeter
Pirates
Raven Shield
Renegade
Republic Commando
Serious Sam
Stronghold Crusader
Swat 4
Underground 2
Underground
UT 2004
Venom
Vice City
Warcraft III
Reply 1 of 17, by Dege
I can say that I ran into the same problem recently. I also have a 1060 6GB, and I got well reproducible crashes with D3D12 with certain games.
I checked it out and it revealed that the NV driver returns an error under unknown(?) circustances to the DXGI rutime inside IDXGISwapChain::Present method (when presenting a frame).
In response the DX12 runtime transitions the DX12 device into DEVICE_REMOVED state at once, which is a straight way to a crash with dgVoodoo. The DX debug layer did not report any error or warning.
So, nothing that I could handle in dgVoodoo, it's driver internals so I don't know the reason of the error either. NV should be asked about it but I don't think they'd bother with it.
The solution for me was going back to an older driver, I chosed the newest one (from 2021 december or so) from the available older ones from the NV page.
And all the crashes was gone.
Oh, and I had no problems with AMD and Intel.
My everlasting experience with NV drivers that new ones just don't fit to old hardware, no matter if they are officially supported, I always run into bugs with them.
The newest one is the D3D12 resource transition bug which I had to workaround in the latest WIP.
Reply 2 of 17, by mitradis
Thank you for your reply. How running record with OBS Studio eliminates CTD? This could be the key to fix.
Reply 3 of 17, by mitradis
But with https://github.com/elishacloud/dxwrapper/ and ForceDirect3D9On12 option no CTD in U2. BUT! With dxwrapper in Space Rangers 2 game with option ForceDirect3D9On12 i have CTD with error.
Reply 4 of 17, by eddman
I remember reading posts on nvidia forum about bugs being fixed based on reports. There are two ways for it:
Feedback form: https://forms.gle/kJ9Bqcaicvjb82SdA
Developer bug report (need nvidia account): https://forums.developer.nvidia.com/t/how-to- … rt-a-bug/160853
https://forums.developer.nvidia.com/t/if-you- … his-first/27131
It's worth a try.
Reply 6 of 17, by mitradis
Dege what version of driver are you using? My old driver was 528.02 (2023.1.5). I try find version where good work d3d12 wrappers.
Reply 7 of 17, by Dege
But it's strange, I'm pretty sure I installed an older one. Maybe it's been upgraded by an update.
Anyway, I get no crashes with this.
Reply 8 of 17, by mitradis
I did some research and found out the latest working version for NFS Underground 2 is 537.58. Next 545.84 version have CTD.
as far as I understand the owners 20**\30**\40** don't have this problem? I mean surely this isn't a common driver problem? Otherwise, this can be considered sabotage against wrappers.
i send report to NV. PLS ALL SEND REPORT WHO HAVE THIS PROBLEM!
Reply 9 of 17, by Dege
Thanks!
I don't know if only the 10xx series is affected. But it can easily be the case because I guess only the driver pack is the same for all series not the drivers themselves.
And even drivers can run on different paths depending on the underlying hw.
Reply 10 of 17, by mitradis
Raven Shield still crashed even on 528.02. Apparently I didn't know about this because I didn't run the second level (Swiss Alps). Apparently these problems started a long time ago. I won't check very old drivers, there's no point in that.
Please don't stop supporting d3d11! After all, I think this is the most stable (fail-safe and working) mode.
Reply 11 of 17, by mitradis
What you thinking about OBS Studio? Why if running record no crashes?
Reply 12 of 17, by Dege
I don't know. For me, the driver error came from presenting the scene, which could be caused by an internal scheduler (falsely) detecting too many frames or sg like that. If it is hooked and the load is less then it might alter the detection and no error code generated. Or sg like that, but it's only pure speculation from me.
Reply 13 of 17, by mitradis
in v2.82.3 CTD in R6 Raven Shield still happen, U2 didnt check (delete this game, this game uses too much deception). Iam back to latest 551.23 and toggle all games to d3d11* mode.
Reply 14 of 17, by Squall Leonhart
Dege wrote on 2024-01-25, 17:16:
Without seeing your code, make sure you're doing your resource deletion on the start of the next frame rather than the end of the current, Nvidia's Tiled Cache implementation can still be using resources if you delete any tertiary resources too early, and with D3D12 a pagefault here is a device removed condition rather than undefined behavior and funky graphical artifacts like it is with D3D11.
A driver update was linked to a regression in the same scenario with CorsixTH, but doing these deletes at the end of a frame has always been a potential race condition.
The crash isn't actually in IDXGISwapChain::Present, its just the last frame logged when the condition is met. (Need to use breadcrumbs in DRED to get more indepth device removed info, or nsight aftermath).
For D3D12 debugging, you want nsight or DRED rather than just the debug layer its own.
Reply 15 of 17, by Dege
But I don't delete resources at the end of the frame. They are only deleted when the corresponding frontend object itself, or an internal cache entry or something like that is released, and of course all affected resources are deleted in a deferred way, when they are no longer being processed by the GPU and not being scheduled to execution in a waiting command list. The debug layer catches those cases nicely. I can reproduce the crash with a certain game, and in each case I get this:
D3D12: Removing Device.
D3D12 ERROR: ID3D12Device::RemoveDevice: Device removal has been triggered for the following reason (DXGI_ERROR_DEVICE_HUNG: The Device took an unreasonable amount of time to execute its commands, or the hardware crashed/hung. As a result, the TDR (Timeout Detection and Recovery) mechanism has been triggered. The current Device Context was executing commands when the hang occurred. The application may want to respawn and fallback to less aggressive use of the display hardware). [ EXECUTION ERROR #232: DEVICE_REMOVAL_PROCESS_AT_FAULT]
D3D12: **BREAK** enabled for the previous message, which was: [ ERROR EXECUTION #232: DEVICE_REMOVAL_PROCESS_AT_FAULT ]
Exception thrown at 0x75FC0F22 (KernelBase.dll) in Nosferatu.exe: 0x0000087A (parameters: 0x00000001, 0x0E5FB2DC, 0x0E5FBF58).
Unhandled exception at 0x75FC0F22 (KernelBase.dll) in Nosferatu.exe: 0x0000087A (parameters: 0x00000001, 0x0E5FB2DC, 0x0E5FBF58).
When IDXGISwapchain::Present is called, the internal SubmitPresent returns an error code from the driver, it gets converted to HRESULT by NTStatusToHResult and a device removal is triggered.
I didn't yet try DRED but that error code is either fake and the real reason is not a device hung or it is real and the GPU hangs executing some command list submitted earlier and Present is just the point where it is detected.
I don't have an idea for the hung because I'm pretty sure the shaders are OK, there is no out-of-bounds addressing, there are no invalid/relesed resources and such. Those cases are detected by the dbg layer and GPU based validation anyway.
Interestingly, if I force "synchronized command queues" then the problem goes away. But I use 1 queue during rendering, and my GPU only has 1 graphics queue. So, if "synchronized queues" are disabled (by default) then the debug layer won't wait for the previous command list to be finished before submitting the next. That's the only difference if I get it right. The driver has problems scheduling the submitted command lists into that only one queue under certain conditions? I don't understand, but it was a driver update that broke it (and AFAIR there is no problem on other vendors, including my Adreno gpu).
Reply 16 of 17, by Squall Leonhart
What game is that?
Is this a pascal laptop?
Also are you using the windows sdk version of D3D12 or agility?
That's the most likely scenario,
Pascal is known to be a bit spotty with using barriers within a feedback loop, but doesn't experience the conditions that require them on Turing+, mind you I speak from a vulkan sense here as the condition was identified with Yuzu on TOTK specifically (and i can't refer back to the bug report for obvious reasons.)
Reply 17 of 17, by Dege
What game is that?
Nosferatu, but it is not special in this regard. The needed condition for me is having a very high fps, like 1000+, in general.
I tried it with a scene demo (title: 604, dx7, so no complicated shaders and anything like that) that starts at 1600-1800 fps and I get this very same crash consistently right at the beginning.
The "old" driver works fine, producing the same performance.
It's a plain desktop, NV GTX 1060 6GB, Win10 (so, yeah, it's Pascal AFAIK) (and I hoped this problem only affected the old architectures)
Hmm... you mean resource barriers? Because I ran into (and it was also reported) a wrong barrier transition on driver side, even with the "old" driver. It could not handle DST_COPY -> PIXEL_SHADER_RESOURCE transition properly. I could only workaround it by inserting an intermediate COMMON state to the transition chain, between the two states. (Again, there were no problems with other vendors.)
Anyway, if NV has a report/feedback side then I could give them 604 as an example for the crash ( ~10MB ). But I never got any reply from any company, so I don't have high hopes for it.
Edit: I use the Win SDK debug layer. I cannot use agility with dgVoodoo.
