First post, by alexparr
Anyone remember that 486 computer I was building and posting about a few months back? Well shortly after those posts, it died right in my hands.
Earlier today, I tried to see if I can revive it with a new video card (thinking the old video card died) to no avail. So now I'm on here, asking if anyone's able to repair this thing.
Currently, the situation looks like this:
- The computer will display no video at all
- The power supply works, being only a few months old
- Keyboard indicator lights (caps lock, num lock, scroll lock) do all light up for a short period upon power up. After that, pressing any of the respective keys will not bring them back on
- No idea if it's the motherboard or CPU, but the CPU seems to get about as hot as it did before the system died so 😒
- Extra peripherals used with the computer include a 300W power supply, the aforementioned video cards, a controller card (with a 3 1/2 floppy drive and Compact Flash adapter connected) and a PS/2 keyboard with the appropriate adapter
- Possible suspects include the motherboard (despite providing power to the keyboard), the CPU (a computer can't show video without a functional CPU, right?), and the controller card (previous testing showed that it couldn't work without any kind of drive connected? I only have old video footage to go off of)
For further information, I live in the United States and would like someone who has experience with repairing 486 computers.
Attached are a few pictures of the motherboard from months back, and cosmetically, it looks basically the same now as it did before. I seriously don't know what went wrong. HELP!
    571.1 KiB
    A picture of the bare motherboard, circa August 4, 2023.
    377.14 KiB
    A picture of the motherboard with most of the aforementioned components attached, circa August 9, 2023.
Gateway 500S:
OEM Intel D845PT
Pentium 4 @ 1.80 GHz
256MB RAM
GeForce4 MX 440
SoundBlaster Live! CT4780
CAPS MAY HAVE FAILED, NEEDS MAINTENANCE
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
CURRENTLY OUT FOR REPAIRS
Reply 1 of 53, by TheMobRules
I'm nowhere near the US so I cannot offer to attempt a fix, but one thing you should consider is getting a PCI/ISA POST card on eBay (they're very cheap). It will let you know whether the CPU is trying to execute BIOS code, which is an important first step when troubleshooting a board.
Reply 2 of 53, by Shponglefan
I second the recommendation for a POST card. It's one of the most useful pieces of hardware to have for troubleshooting older hardware.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 53, by rasz_pl
do you have pc speaker connected? does it make any sounds?
try clicking numlock - does the keyboard LED change color?
Those two are tests meant to determine if CpU/BIOS is trying to run at all, the only thing you need to perform them is motherboard with CPU, power and keyboard connected, everything else removed.
Reply 4 of 53, by alexparr
TheMobRules wrote on 2024-01-26, 03:25:
...one thing you should consider is getting a PCI/ISA POST card on eBay (they're very cheap). It will let you know whether the CPU is trying to execute BIOS code, which is an important first step when troubleshooting a board.
It's only now that I hear about this actually useful utility... I'll get one when I can.
rasz_pl wrote on 2024-01-26, 04:34:
I probably should've mentioned that; no, I don't own a PC speaker to connect. After the initial flash of the keyboard lights, none of the keys seem to do anything; not even Num Lock.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 6 of 53, by alexparr
Just bought a POST card off of Amazon. That was the cheapest and quickest I could get one. (:
It has a piezo speaker as DerBaum mentioned:
DerBaum wrote on 2024-01-26, 13:55:
you can get a post card with a speaker (buzzer) that solves basically all problems at once 😁
As well as everything else that I think a POST card is supposed to have. (number display, indicator lights, PCI/ISA slots, etc.) Attached is a picture of the card I bought.
It's supposed to be here by the 31st. In the case that it gives out an error that I can't fix, (which, if it does happen, it will be a few days from now) does anyone still want to take a stab at repairing my system?
    189.98 KiB
    A picture of the PCI/ISA POST card I purchased.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 7 of 53, by rasz_pl
alexparr wrote on 2024-01-26, 12:48:
Keyboard initialization is right at the top (~10th routine) of bios startup sequence, so that means either POST fails very early, or your CPU is not running at all. Might be difficult to diagnose without spare cpu/motherboard.
You might want to either narrow it down, or look for HackerSpaces in your area, there usually is at lest one Vintage enthusiast hanging around a hackerspace 😀
Reply 8 of 53, by alexparr
rasz_pl wrote on 2024-01-26, 14:26:
I'm hoping it's the latter, as I do not want to spend upwards of $100 on a motherboard with a similar feature set to this one.
I have never heard of hackerspaces until now. Why am I suddenly finding out about these useful resources now?!
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 9 of 53, by rasz_pl
alexparr wrote on 2024-01-26, 17:07:
Its quite recent phenomenon. Makerspaces/Hackerspaces started showing up after 2005, thats when Maker magazine started publishing just after 3D printing became available to amateurs thru RepRap project and Arduino opened microcontrollers to laymen. When I was growing up in the eighties we only had 'Modelarnia' roughly translated to 'Model building workshop' - a woodworking and electronics shop for kids to built RC models
https://kok.kepno.pl/modelarnia-2/ https://www.mdkstalowawola.pl/2018/09/05/miej … -organizacyjne/
and HAM (amateur radio enthusiast) clubs. My primary school still had woodworking workshop up to around 1992. One year we were whittling wood for final grade, I remember making an ergonomic shaped base for a homemade joypad 😀, the next wood shop was gone and we were learning Turbo Pascal on really crappy ATs with small HDDs and EGA monitors.
Reply 11 of 53, by alexparr
I got the post card, plugged it in and this is all it displays.
[ -- --, -12V, +12V, +5V, CLK ]
I'm not sure if my card is faulty or not, but it seems to do the exact same thing when powering up with the CPU removed.
Before I go and rush-order more parts though, I thought I'd come back here. Does anyone with a POST card know what this means?
    1.02 MiB
    A POST card that shows the following: "-- --" -12V +12V +5V CLK
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 12 of 53, by Shponglefan
alexparr wrote on 2024-01-30, 22:14:
I got the post card, plugged it in and this is all it displays. [ -- --, -12V, +12V, +5V, CLK ] I'm not sure if my card is fault […]
That means the motherboard is not POSTing. Which typically suggests a significant problem. It's not clear on whether it's the motherboard or CPU.
This is where having multiple components can come in handy to swap parts around and narrow things down to one component.
Reply 13 of 53, by pc-sound-legacy
That's bad news I guess. If there were no post codes displayed that means the BIOS don't even start to do anything. Reason might be broken CPU, wrong jumper settings for CPU or dead BIOS as an example. The LEDs indicating the supply voltages are present and there's no short/reset. (Idk why there's no 3.3V supply on the PCI bus but maybe thats normal for early pci on 486?)
Reply 14 of 53, by CoffeeOne
Does the cpu get warm when you start the board? You can "measure" it with your fingers. For this short test it's good to not put a heatsink on the cpu.
If its getting warm / hot (after lets say 10 seconds), then at least power is provided to the cpu.
Did you always run the DX2-66 without a heatsink? Just asking because I did not see one on those pictures.
EDIT: I overlooked that you already wrote that the cpu gets hot, sorry.
OK, maybe try underclocking it, so set the bus to the lowest value, like 25MHz.
Reply 15 of 53, by alexparr
Shponglefan wrote on 2024-01-30, 22:25:
Before I posted about it, I tried it with and without all of the expansion cards I had plugged in, as the manual suggested. Same result.
pc-sound-legacy wrote on 2024-01-30, 22:30:
I never messed with the jumper settings, so it can't be that.
CoffeeOne wrote on 2024-01-30, 22:48:
As I stated in the original post, it gets about as hot as it did before the system died. It didn't come with a heatsink when I ordered the motherboard—yes, the motherboard came with the CPU pre-equipped, with the jumpers already set to their correct values for said CPU.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 16 of 53, by alexparr
I never messed with the jumper settings, so it can't be that. It would kinda suck if the BIOS died on me, as that's another thing that can't be easily replaced—at least in my case.
...Did you always run the DX2-66 without a heatsink? Just asking because I did not see one on those pictures.
I don't know what jumpers do what. There is no documentation about this motherboard, so I'm kind of just stuck at 66MHz—unless of course I want to break something else.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
Reply 17 of 53, by Jasin Natael
Remove any cards or peripherals that you don't need (sound, drive controllers etc), pare it down to just PSU/MB/CPU/RAM/Video.
Reseat everything, including ram, cpu etc.
Check all jumper settings.
Start there.
Reply 18 of 53, by CoffeeOne
alexparr wrote on 2024-01-30, 22:56:
The setting is actually printed on the mainboard, the setting for 25MHz, 33MHz and 40MHz is documented.
So set it to 25MHz and check what happens.
EDIT: There are 2(!) sections with the writing: 25, 33, 40 MHz. But I cannot read that clearly from these pictures
MORE EDIT: If I were you, I would get another cpu. Running a DX2-66 without any heatsink for a longer period of time might have killed it.
Reply 19 of 53, by alexparr
CoffeeOne wrote on 2024-01-30, 23:03:
The setting is actually printed on the mainboard, the setting for 25MHz, 33MHz and 40MHz is documented. So set it to 25MHz and c […]
The ones on the left seem to be for the PCI bus. The ones in the middle are un-labeled. Remind me though, what does "OP" and "CL" mean?
Also for some reason JP13 doesn't have any jumper pins connected.
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
486 Project:
Jetway Motherboard
i486DX2 @ 66 MHz
8MB RAM
S3 Virge/DX
