First post, by envagyok
The question at subject:
What Sound card built 95-96 and has bug free daughter board connector, and has good audio quality?
AWE32 -Not good, because all has midi bug
AWE64 - Not good, because not has daughter board connector
Reply 1 of 11, by Shponglefan
Does it have to be 1995/1996 specifically?
For something readily available, I would recommend a basic Yamaha Audician 32 card. There are a handful of different models that are typically readily available for different manufacturers. Most common seem to be the Labway A151-A00 cards.
There are other cards from mid-90s like the Guillemot Home Studio Pro, Media Vision Pro Audio Studio 16XL, and the Media Vision AudioTriX Pro. These cards are much more rare and command a significant dollar value when they pop up for sale.
Another option would be a modern card like the Orpheus II / Orpheus II LT.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 11, by envagyok
I search between awe32/awe64 time period.
Or maybe litlle older, from time soundblaster 16.
Strange, there is a midi daughterboard header on many sound card, but almost all has problem with midi.
Reply 3 of 11, by Joseph_Joestar
Shponglefan wrote on 2024-01-27, 15:14:
While Yamaha YMF 71x cards do have a bugfree MPU-401 interface, the wavetable header on some models has the stereo pins reversed. This can be fixed by a hardware mod as shown here by James-F.
I think some ESS AudioDrive cards may have the same issue. Not sure if this problem is present on OPTi and Crystal based cards.
Reply 5 of 11, by Shponglefan
envagyok wrote on 2024-01-27, 15:36:
Is there any reason you're confining yourself to that time period though? Unless you're specifically trying to do a period correct build, I wouldn't worry about when the card was manufactured.
Reply 8 of 11, by envagyok
Unfortunately i don't have Gold.
Reply 9 of 11, by orcish75
Not sure if you're any good with electronics, the hanging note bug can be fixed by replacing the DSP chip with modified firmware. Check this thread, it's long, but well worth it.
The Soundblaster DSP project
Reply 11 of 11, by envagyok
@orcish75
I'm not good with electronics.
@1541
For me better without new 3rd party patch.
