First post, by Rikintosh
I'm looking for a USB card to purchase, I tried via 6202, but it only works on some computers, and it definitely doesn't work on my Intel Advanced/AS AT which doesn't have 3v, or ACPI, installing the driver will crash the computer, or it will crash during boot.
So I decided to look for NEC, I didn't have much luck, there aren't many in my country, and I don't want to import one because it would be stuck for 60 days for customs evaluation. I found this one, but it seemed very modern, despite the PCB design being 5v and 3v, and the seller states that it is compatible with Win 98, I would like to know if anyone has had any experience with this board
I also found older second-hand boards, with only two USB ports, they seemed more "compatible" because they were old, but they had OPTI and Ali chips. I wish it wasn't necessary for additional drivers to use the board.
    1.6 MiB
    1.72 MiB
    379.3 KiB
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
Reply 1 of 1, by dominusprog
I have a card with the OPTi chipset, the same as yours. It work in Win95 with eXtended USB Supllement installed.
https://msfn.org/board/topic/177518-xusbsupp- … indows-95-osr2/
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
