First post, by rolloLG
- Member
I use SBPro for digitized sounds, and I tried POP2 1.0, 1.1 and IR (initial release) version but all of these versions under DOSBox suffer a strange problem with missing some sounds: once is sword swoosh, with another version there is no steps sound.... SB is working fine with other games and is configured as "SET BLASTER=A220 I7 D1 H5 P330 T6". The bugs seem in Prince Of Persia 2 itself...
As a check just use ALT+N up to the cave level I use for testing... do a few steps and extract the sword and press fire. Some versions have no step sounds, others have no swoosh sound using the sword.
Or maybe the sword swoosh is by design audible only in combat?
To be exact, this is the detailed list of gfx/audio glitches I've found in POP2:
v IR = no steps sounds, muted missing sword swoosh sound except in combat
v 1.0 = has steps sounds, muted missing sword swoosh sound except in combat
v 1.1 = has steps sounds, muted missing sword swoosh sound except in combat, has a ugly gfx glitch entering exit doors in the cave level (sprite passes through the wall):
There are also some YT videos showing this issue, for example (v IR I guess):
https://www.youtube.com/watch?v=_VM3ECIH2wA
(no steps sound, at 16:28 you can also see the muted sword swoosh after combat vs skeleton ends)
SCAR 18 G834JY: i9-13980HX, 32GB DDR5@5600, 4090 laptop 256 bit 16GB, 2560x1600 16:10 G-Sync, NVMe 6GB/s, 8BitDo Arcade Stick, EasySMX X10 controller, ROG Strix Carry Mouse.
