MS-DOS 6.30 ?
First post, by Jo22
Hi there! Was just preparing a bootable MS-DOS 6.22 boot-disk for use with PC-Ditto emulator (on Atari ST).
When I tested the boot-up floppy, it reported back MS-DOS 6.30! Is that normal?
Details see screenshot.
    19.43 KiB
Reply 1 of 6, by Sphere478
How odd.
Dos under windows eventually went to 7.?
Sphere's PCB projects.
Reply 2 of 6, by Grzyb
Looks like fake.
It would be a good idea to compare files of that "6.30" and genuine 6.22 - very likely the only difference are the bytes where version number is stored.
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 3 of 6, by Cyberdyne
The fakest 😂
Reply 4 of 6, by Jo22
All I did was using my normal DOS 6.2 installation to prepare an bootable diskette for use with PC-Ditto.
Reason for this was that the problem was that the Atari ST emulator had issues with normal 720KB images (*.ST vs *.IMA wasn't the main issue here).
So I've tinkered with certain floppy drive geometries to make everything more ST floppy drive friendly.
The Ditto manual recommended using FORMAT A: /1 /S to prepare an 3,5" 720KB floppy in SD format.
That was very troublesome, because FORMAT refused to do that with a 3,5" 720 KB DD drive (as reported by BIOS).
So I had to tinker with certain BIOS and floppy drive settings (incl 5,25" drives),
until that command worked and something booted up in PCem (that funny MS-DOS 6.30 message).
In the end, it didn't really matter, though.
The emulator, Winston, had issues with Ditto. Perhaps due to incomplete floppy emulation.
Switching do STEEM solved the issue for me. A normal 720KB DD floppy image was accepted and Ditto booted happily.
I've used both an unaltered PC-DOS 3.30 floppy dump (720KB DD; my own btw) as well as a custom boot disk with MS-DOS 6.20.
It's still funny as to why MS-DOS 6.22 reports as MS-DOS 6.30. The VER command reports the correct version.
Edit: Ah yes.. The weird font. It's a Wyse-700 video board emulation. This one draws everything large in CGA emulation mode.
Reply 5 of 6, by Disruptor
Jo22 wrote on 2024-01-28, 21:46:
It's not that difficult to edit COMMAND.COM with a better hex editor.
Wasn't it Robotron who did the same or a very like thing to create their DCP?
Reply 6 of 6, by Jo22
Disruptor wrote on 2024-01-28, 21:48:
Of course it's not difficult. But I haven't done anything to my installation.
Booting via C drive doesn't show this strange number.
Edit: Just double-checked. There's indeed something wrong here.
Command.com in C:\ seems to have been altered (the one in C:\DOS is fine).
Edit: What makes wonder, though, how did an English "6.30" end up on my localized MS-DOS 6.22 installation ? 🤷
I have no need to grab a random copy of DOS from the interwebs, I do have several originals already here.
Anyway, I'll do an virus scan now. Better safe than sorry.
