First post, by sofakng
I'm using an IBM PC 350 that includes two USB 1.0 ports but they seem a bit useless. USB keyboards and mice don't work in the BIOS or DOS (ie. no PS/2 emulation).
Are there any ISA or PCI cards that will support a USB keyboard and mouse and allow me to control both the BIOS and work in DOS (for games, etc) ?
Reply 1 of 6, by zwrr
You may need this, USB keyboard and mouse to PS2 interface.
https://github.com/No0ne/ps2x2pico
https://github.com/LimeProgramming/USB-serial-mouse-adapter
I'm using it on my 486, connecting a Logitech wireless keyboard and mouse.
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 2 of 6, by wbahnassi
My experience with USB keyboards on DOS is not great. There seems to be a conflict between the keyboard and the PC speaker. Any time the PC speaker is beeping, the keyboard is ignored. If you play a PC speaker game (e.g. Keen 1), gameplay will be ruined. If a game is playing continuous music via the PC speaker, you're effectively locked out of pressing any keys on the keyboard.
A PS2 connection doesn't have such issues onviously. Thus, I also recommend and external conversion device to convert USB to PS2 instead of using the mobo's USB (dunno if extension cards also suffer from the same issue).
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 3 of 6, by douglar
wbahnassi wrote on 2024-01-29, 10:27:
I agree.
1) USB 1.0 was touchy. Hard to predict what would and what wouldn't work. The drivers were often a hot mess. Crashes while hot plugging devices were not unheard of. So that's the baseline that the OP is working with.
2) Next you have your motherboard BIOS. DOS accesses the keyboard through the INT 16 BIOS call. My experience was that finding a BIOS with good USB Keyboard support was rare before 2000. Sometimes one keyboard would work and another one wouldn't. Sometimes the USB keyboard would work in DOS, but could not be used in the BIOS configuration screens, so you needed a PS/2 keyboard to enable USB support. BIOS support for USB add-in boards was pretty much unheard of, so if you find a nice PCI add in board, your BIOS is unlikely to find it. Maybe there were PCI USB cards that come with improved keyboard BIOS via Option Roms. Seems possible but I have not seen that.
3) Then there's hibernation issues. It's not uncommon to see PS/2 - USB devices that don't reinitialize correctly after coming out of hibernation. Easy enough to disable hibernation for retro computers though.
So yeah, it's a minefield of problems. Overcoming them all requires some luck.
Reply 4 of 6, by sofakng
Thanks everybody for the information!
It sounds like if I want a socket 7 PC (ie. Pentium 233 MMX) then I need to use PS/2 (and an active adapter for USB keyboard/mice).
Reply 5 of 6, by Sphere478
sofakng wrote on 2024-01-29, 04:18:
It’s kind of the other way around you need a usb keyboard that supports ps/2 protocol and a ps/2 passive adapter
Sphere's PCB projects.
Reply 6 of 6, by mmx_91
sofakng wrote on 2024-01-29, 14:50:
You can easily get this using a 430TX based chipset board. I've used several with USB keyboards and all of them worked flawlessly.
Intel improved USB support by a lot on their PIIX4 southbridges (used in 430TX or mytical 440BX, for example).
