First post, by Scythifuge
Greetings,
I am having trouble with ATI & Omega drivers for my AIW X800. I have tried 7.10 & 7.11 and cannot run anything in 3d and dxdiag tests fail to create 3d device. Omega drivers for 7.10 work, for the most part, but when I run Just Cause (2006,) there is a weird glitchy square in the center of the screen during menus, cutscenes, and gameplay. I thankfully ran ntbackup before installing drivers so that I can revert and try different sets, but trying to find, download, install, test, revert, repeat over and over again is frustrating to say the least.
Is there anyone running an X800 under Windows XP qwho can recommend the best driver for this set up?
Many thanks!
Scythifuge
Reply 1 of 2, by Scythifuge
I just tried the official 6.9 drivers, and the dxdiag tests were a success. I am now installing Just Cause to test for that weird center screen box-glitch. If the glitch is gone, I will probably stick with these unless someone suggest a better alternative. Now, if 6.9 is what I stick with, I will need to find all of the All-In-Wonder apps which are compatible with Catalyst 6.9.
Reply 2 of 2, by Scythifuge
Does anyone know where I can find the AIW files specific to 6.9? The Multimedia Center, DVD decoder, TV tuner stuff, etc.?
