First post, by Mamba
Hello,
I am searching for this on the net for a while, but I am not able to find a patched bios to overcome the 32gb of this MVP4 motherboard.
Of course I can use SATA controllers, but it would be nice to use onboard ATA66 one.
Any advice?
Reply 1 of 2, by Horun
Hmm which bios date do you have ? the newest one on TRW, Mitac archive, etc all have 11/07/2001 date. A bios that new should support up to 127Gb....
added: attached a zip of the orig 11/07/2001 bios update +flasher, added a txt file.
Reply 2 of 2, by Mamba
I have the latest one, I think it is the same you linked.
XP loading hangs so I was thinking it was because of the limitation (loading from a Samsung 830 120gb ssd).
