First post, by CoolDoomer
I got a Quantum EX 5.1 hard drive that seems to have these symptoms:
It has the code: EX51A014 REV 01-B. It should have 5GB.
1. Primary Master IDE is not recognized
2. It throws an error after detecting all Hard Drives.
The attachment BIOS1.jpg is no longer available
3. In bios it identifies wrong C/H/S and Size values.
The attachment BIOS2.jpg is no longer available
3. It makes booting Windows XP Last around 5 minutes.
4. Hard disk sentinel doesn't display any information.
The attachment HDDSentinel.PNG is no longer available
5. Trying to use Atola HDD capacity Restore inst able to identify the factory settings.
The attachment untitled2.PNG is no longer available
The attachment untitled.PNG is no longer available
HDD spins and doesn't sound strange. The green LED on the PCB behind the Hard drive is light and blinking.
I feel this is an firmware issue. If someone with HDD experience can help me, I would be grateful.
Reply 1 of 6, by CoolDoomer
I forgot to say I tried on other 2 functional motherboards and it causes the same issues. Even in Windows 98 it causes some sort of conflicts.
Reply 2 of 6, by PC Hoarder Patrol
CoolDoomer wrote on 2024-02-04, 20:17:
I got a Quantum EX 5.1 hard drive that seems to have these symptoms: It has the code: EX51A014 REV 01-B. It should have 5GB. […]
Specs attached ...
The attachment fireball_ex_specifications.pdf is no longer available
Try running it as the only attached drive, using the Quantum diagnostic app (attached - creates a bootable floppy)
The attachment qdps102.exe is no longer available
Reply 3 of 6, by CoolDoomer
Thank you. Tried using that. It still recognizes the drive with 000.. serial and it cannot select the drive.
Reply 4 of 6, by CoolDoomer
CoolDoomer wrote on 2024-02-05, 07:51:
Here is how it outputted:
The attachment foto_no_exif.jpg is no longer available
Reply 5 of 6, by rasz_pl
modern (as in last 30 years) HDDs keep configuration and firmware directly on HDD platters in special service area. HDD dies if that data gets corrupted and drive cant recover using spare copy. Serial number 00000 looks like drive failed to fully initialize itself.
Reply 6 of 6, by verysaving
QUANTUM ECLIPSE PLUS seems like a family model.
Looks like HD couldn't load firmware from platters
and you got ID from PCB bios.
This means usually bad heads or media damage.
I would try unscrewing the controller and clean any
contact between PCB and the HDA and see if this
make any difference.
