First post, by twiz11
my computer room has two types of flooring that i run my chair over and i got cracks that are an eyesore. what in your opinion would be a good filler?
Reply 1 of 3, by BitWrangler
Best guess from me is that you get a urethane based caulk/sealant and mix a pigment in for closest match. Things like epoxy would be too hard in that surface and crack up, or cause cracking around them. Things like latex caulk/sealant would maybe be too soft and not durable enough.
