First post, by Morotz
Hi, this is my first topic here. I just wanted to share this.
The story begins March 2018, when I bought an untested (you know what this means) Voodoo 3 2000 AGP from an eBay auction for about 35€. Turns out it's defective, showing obvious visual artefacts even in BIOS.
As I didn't have much clue at that point, the project laid dormant for 3 years. In the meantime I learned lots about soldering and repairing old hardware and got confident enough to make an attempt at repairing it. Checking the board thoroughly, co damaged components or traces could be found and based on the shape of the artefacts, I suspected defective memory. On AliExpress I managed to source 5ns TSOP memory with identical layout (I guess all TSOP memories with the same pin count have identical pin layout) and started by removing the original memory chips. With my hot air gun I moved some capacitors which I quickly fixed. Luckily, nothing got damaged in the process.
After installing the new 5ns ESMT memory (M12L16161A-5T), the card did not work and still showed artefacts! So I got back at it and checked all solder connections, fixing a couple bridges in the process.
Honestly, I don't remember whether I even tested the card again afterwards and the project fell to the side. Now, after 3 more years I decided to give it one more go and it promptly worked!
On my Athlon XP-M Abit KT7A System, it achieved 5731 points in 640x480x16 bit 3DMark2000. I really like the socket A platform for retro gaming with its ISA compatibility. I don't mind the VIA 686B south bridge bug as I use a Vortex2 instead of a Soundblaster. 512MBs of PC133 CL2 memory are probably the slowest part of the system. The CPU (Athlon XP-M 2400+ AXMD2400FJQ4C) is running really cool at 1.30V 1600MHz. It is super late, built in week 8 of 2005!
With the 5ns memory, I had hopes of improving the overclocking potential of this card. If I replace the memory anyway, might as well just upgrade it. Optimistically, I used the Voodoo Tweaker to set the speed to 166MHz (from stock 143MHz) and the system instantly froze. After a couple tries, it didn't even work at 155Mhz. So far, I only managed to successfully run 3DMark2000 at 150Mhz, which is just a very slight OC. Adding cooling fans might help, but this is still far less than I hoped for. But the most important thing: it works perfectly fine and stable.
This gives hope to another project of mine, a Voodoo 5 5500 PCI with similar artefacts. I already ordered new 6ns memory for it. But for now, my exams have priority (I am younger than every 3dfx card).
Retro systems:
Athlon XP-M 1600MHz, Abit KT7A, 512MB PC133 CL2, Quadro FX3000, Vortex2 + SB AWE64, Win98SE
Athlon 1100MHz, Geforce2 Ti, Win2k
Pentium III 550MHz, Voodoo 5 5500, Win98SE
Xeon L5430, 4GB DDR2, GTS 450, WinXP
Reply 1 of 7, by Morotz
Oh well, how do I fix the images? The order makes no sense now
Retro systems:
Reply 2 of 7, by darry
That Ali Express RAM might not actually be 5ns . It might have been re-marked.
EDIT: Congratulations, BTW, on a job well done .
Reply 4 of 7, by Morotz
Thanks for your replies! Ali Express fake RAM would explain the poor overclocking. Perhaps I will investigate this more in the future.
Retro systems:
Reply 5 of 7, by Thermalwrong
Nice fix! Personally I think that RAM is legitimate but not from the highest quality manufacturer. Week 29 of 2010 manufactured SDRAM would be going into a router or a digital picture frame, things like that. It's probably better than the original chips anyway from process improvements.
The history of the card seems a bit suspect so it's great you now have it working - but look at those MLCC capacitors by the voltage regulator and around C71, no way it came out of the STB factory looking like that.
For the overclocking, you should look into boosting the voltage of the regulator on the card, the 3000 has higher core voltage than the 2000 - see page 45 of the "voodoo3-databook.pdf" for details. Looks like 2.55v (2000) vs 2.7 (3000), that's set by a pair of resistors that make up a voltage divider near the voltage regulator.
Checking my 3000 at a guess I'd say the pair are R27 (marked 15A) & R23 (marked 09A) and the numbers check out:
2.69 KiB
You could either swap the resistor values to match the 3000 or you could follow this video guide which is less permanent: https://www.youtube.com/watch?v=TUJ--Y2B6LM
Be sure to improve the cooling if you do up the voltage. I recommend against removing the heatsink to start with, just add a fan.
Reply 6 of 7, by analog_programmer
Thermalwrong wrote on 2024-02-12, 02:51:
On his YT channel (Bits und Bolts) scorp made a pretty interesting series of videos with Vodoo3 2000 undervolt+overclock tests. I think the final one pretty well shows the limits for this videocard: https://www.youtube.com/watch?v=Nf9D67whqA0
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 7 of 7, by Morotz
Thanks for the information! If I have a potentiometer laying around this sounds like a fun overclock.
Regarding the crooked SMDs near the voltage regulator and C71, the solder connection looks original. Weird that it happened, but as long as they work I just leave them as-is. I don't think I have ever seen this on another card.
Retro systems:
