First post, by mockingbird
Hi,
I have a generic SIS315E graphics card (AGP) that doesn't output correct resolutions for their respective modes... Or rather, this is the case for at least some of the resolutions. What this means is that at certain resolutions, I get 'out of range' or similar messages on LCDs. An example is the POST screen, which does not display, but then DOS does display properly after POSTing.
I've tested BIOS 1.13.03 from the VGA Museum's page, and that did not help.
Here is a photo of my card:
925.52 KiB
If anyone has a different BIOS I could test, I'd be grateful. If the BIOS is larger than 512mbit (64kb), that's fine, I can desolder the 26-pin socket and install a 30-pin socket for a larger EEPROM. I've already replaced the OTP EPROM which came with it (A276308A) and installed a W27C512 which worked fine.
Thanks
(Decommissioned:)
Reply 1 of 6, by ciornyi
I believe I do have green one , if you could tell what software needed I'll be able to get this
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3_900/256mb/SB live/3dfx V3
Win Me: Athlon 1700+/512mb/Audigy2/Geforce 3Ti200
Win XP: E8600/4096mb/SB X-fi/HD6850
Reply 2 of 6, by dominusprog
ciornyi wrote on 2024-02-09, 13:33:
You can dump the BIOS with NSSI.
https://navsoft.cz/products.htm
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 6, by ciornyi
Finally able to find my card , it's have plc 28/32 bios chip , idk if it matters
    1.6 MiB
Reply 4 of 6, by mockingbird
ciornyi wrote on 2024-02-11, 17:42:
cool - are you able to dump the BIOS? You should get a 64KB file.
(Decommissioned:)
Reply 5 of 6, by ciornyi
here is bios
    SIS315.zip
    28.58 KiB
    10 downloads
