First post, by Jo22
Hi everyone,
I've just found a solution to an VGA-related issue in my ancient copy of Qemu and like to share it.
The issue was about a garbled VGA output in the APRSDOS application, which also affects synthetic VGAs in Virtual PC 2007 and VB.
The reason I've used Qemu was its higher compatibility to USB serial converters.
DOSBox and several other emulators can run APRSDOS just fine but have trouble with these converters (frame issues, 5-Bit format etc) or don't support serial ports (PCem).
86Box technically was a promising alternative, but the author went full 64-Bit or Vista+, so it won't run on my XP host anymore.
Anyway, long story short, the fix/wirkaround was to load the RAMBIOS utility for the emulated Cirrus VGA. It's part of the Cirrus driver diskettes.
That solved the graphics issues for said application.
I'll add some pictures soon, when I'm home.
Edit: Screenshots attached.
    16.59 KiB
    APRS splash screen (garbled)
    20.46 KiB
    APRS main screen (garbled)
    18.24 KiB
    Loading RAMBIOS program (VGA141.EXE)
    22.47 KiB
    APRS splash screen (ok)
    27.28 KiB
    APRS main screen (ok)
Reply 1 of 2, by Jo22
Hi again.
Here some more screenshots of my old copy of Qemu.
Most notably, it starts a Windows popup dialog for my serial port.
Qemu supports one serial port.
My settings..:
[qemu-win DOS.bat]
qemu.exe -L . -m 16 -hda dos2.img -soundhw sb16 -localtime -M pc -serial COM4
Programs..:
qemu-0.9.1-windows.zip
Kqemu-1.3.0pre11-install.exe
I'm also using some exotic memory tools for real-mode DOS (v6.22), to make room for applications.
MAXMEM.SYS driver for M$DOS 7.1 (by CandyMan)
UMBPCI c't 11/95( v3.80, updated by Uwe Sieber in 08/2009)
The usual MS-DOS drivers are left as is.
I've tried to replace KEYB by a smaller version, but this didn't work well.
Either the arrow keys made two movements, or the CTRL+ALT combo for "\" wasn't supported.
The SB16 driver package was being used, too, with the exception of CTCM - it stalled due to the many PnP devices.
To enable serial port's 16550 FiFo, the COMS.EXE program was being used.
It's part of smc.zip archive, which also has an updated Win3.1 serial driver.
But really, any other utility may do as well, suppose.
The RAMBIOS utility of utilv141.zip was being installed at the very bottom of the autoexec.bat.
    33.29 KiB
    The Windows serial dialog called by Qemu
    16.68 KiB
    Qemu starts..
Reply 2 of 2, by darry
Nice! Thank you for sharing.
That strangely reminds me of the issue I was hitting with a Voodoo 3 in QEMU KVM I was finally able to succesfully (mostly) PCI passthrough a real PCI Voodoo 3 2000 to a Windows 98 SE QEMU KVM VM .
In your case, I would guess that a reverse engineered work-alike BIOS image is provided and used by QEMU by default and it has bugs/issues that the actual Cirrus Logic BIOS does not have .
