MT32 Display Mod / sed1200emu
First post, by Delphius
Project page can be found here: https://github.com/RetroLoom/sed1200emu
Original post:
Hello Vogons,
I became interested it MT32 display replacements a while back but have only found a few mentions here and there about any current projects. I have ran across this sed1200emu project a few times but there is very little information and documentation about it.
http://sensi.org/~tnt23/sed1200emu/index.html
So to satisfy my own curiosity I decided to take some initiative and try and build one of these, and maybe get the ball rolling on some options and collaboration for something like this. My displays work fine on both of my MT32's, but I wouldn't mind preparing for a replacement or finding something that looks cleaner and brighter than what is stock.
I have PCB's built, IC's programmed, most things plugged in, but I am stuck and do not wish to continue without more information and planning for what to do next.
The attachment sed1200emu test 1.jpeg is no longer available
The attachment sed1200emu test 2.jpeg is no longer available
The attachment sed1200emu test 3.jpeg is no longer available
The attachment sed1200emu test 4.jpeg is no longer available
Everything powers on with the new display with a seemingly initialized row, but data does not seem to be registering from the MT32. I have two ideas that could be causing this.
First, I am not certain if the oscillator I chose is functioning properly. When measuring with the oscilloscope it seems to be all over the place and not produce a solid sine wave. I think this will be the first thing to troubleshoot because I am certain this needs to be working correctly. I am not very familiar with oscillators so it has been difficult for me to know exactly what is required.
Second possible issue is that there are about 6 single pins available on the backpack PCB that are labeled SCK0, SCK, MISO, MISO0, MOSIO, MOSI that I am not sure are required or not for function. The project page does not mention anything about these, or where they might patch to the MT32 if required. I have been scanning through the MT32 service manual trying to see if there is a clear easy spot, but I am not willing to poke around and test without knowing for certain. The project page does mention that there are ground pins that need to be connected for continuity, and those were absolutely required to get the display to power on, but the other pins aren't mentioned.
edit: Also, there is a reset pin on the backpack that may need to be connected but there is no mention on the project page. Reset is high on the atmega, so it may need to be pulled low or connected to MT32 reset line. But so far grounding this to low doesn't have any affect.
Schematics and PCB are available on the project page if anyone cares to take a look, and I can also share some of the files and mouser links to parts that I used if anyone is interested in helping along. I have also sent an email to the project developer and waiting to hear back about any further information.
Reply 1 of 20, by SquallStrife
Delphius wrote on 2024-02-09, 16:56:
These would just be for in-system programming of the MCU. I.e. if you have the ATMega AVRISP, or a USBasp or similar device.
Reply 2 of 20, by Delphius
SquallStrife wrote on 2024-02-14, 21:59:
Thank you for confirming this. I had somewhat assumed something like this originally which is why I had not populated them yet. This build uses an ATMega which I also have little experience with programming. Which also reminds me that there isn't much in the documentation about what flags need to be set for this to work properly. I may end up needing to tap into those to change patch some things.
Reply 3 of 20, by Delphius
I would like to dig this project back up and hopefully get a little help with it. Overall some of these things are very new to me, but it would be nice finishing this as an option for a display replacement or upgrade for the MT32. I have not heard back from the original developer for help or permission to reuse this and post it on github. I would like to make it open source but there does not seem to be any clear license attached to it. I might try to reach them again. I was able to import the original design files into KiCad if anyone wants to take a closer look.
At the moment the display powers on and seems mostly correct. But there are two different things I am considering as problem areas for the build so far.
  • When probing the quartz crystal I am not getting any sign of a sine wave. Just a flat line. I think either I used the wrong type of crystal all together or I used the wrong capacitors attached.
  • Or I did not program the ATMEGA correctly or it is also the incorrect type.
Here is the link to the mouser project I used to order the parts if anyone is interested in taking a look and correcting anything that is wrong.
https://www.mouser.com/ProjectManager/Project … ssID=9896f5d5b2
Here is a screenshot of the schematic and BOM list exported from KiCad.
The attachment kicad_OUqT64gnrD.png is no longer available
The attachment soffice.bin_cGEdcH1lMD.png is no longer available
Thanks in advance for any help with this.
Reply 4 of 20, by Delphius
So I have done a little more research on this and found that it would be more appropriate to use a 16pf crystal instead of a 22pf like the one I am using. I will switch the crystal out and see if that gets me a proper clock.
Otherwise it also seems that the ATMEGA8L-8AU is also the correct choice of ATMEGA8L-8AI as a drop in replacement. I feel pretty confident that I programmed it correctly, but I will go ahead and purchase a second one for experimentation and in case I need to swap it out for any reason.
Reply 5 of 20, by Delphius
I am not sure if anyone is following along with this, but I am happy to report that I was successful in getting this project working!
I spent some time updating the PCB and cleaning up the symbols and footprints that were converted over from the original schematics. There were a few issues with the first production unit, including ground wires that did not seem to be connected to the ATMEGA8. After getting things put together I was still disappointed that things were not working, so I had to deep dive into how to properly configure the ATMEGA8 to use the external crystal and to make sure everything had been flashed correctly. It seemed I was getting closer, but using the HEX file that came from the original website I wasn't able to get any signal on the output of the ATMEGA. So I dove into the source code and updated it to compile under WinAVR / avr-gcc and started doing some testing. It took a little tweaking and trial and error, but I was excited to find out that it was worth the hard work. Everything seems to be working perfectly now and the display is nice and clear.
The attachment sed1200emu working.jpeg is no longer available
This was the first step I had planned out for this project, next will be figuring the logistics for mounting it properly into the MT32. This might be easier said than done because unfortunately this LCD is quite a bit larger than the original so very little chance it will be a drop in replacement. So I am considering what options might be available at this point. One option would be to 3D Cad and print a new styled front face place for the entire MT32 that can handle the screen size. I do not have experience in this area so if anyone is interested in trying it out, please let me know. Otherwise, a 16x2 display might be easier to fit into the original mounting with a few adjustments. Both of these options would require some type of mounting to be designed since the 16x2 LCD is also not a perfect fit. The other issue with a 16x2 is that it would require different programming to fit everything onto the screen. The original is 20 characters wide, but does not seem to utilize the second row. It would be possible to create a 16x2 with scrolling to compensate for any excess characters, or force the excess characters to the second row. Neither of those options seem ideal, but it might be nice to have the option for one or the other. I could also play around with detecting empty characters and removing them for situations like the Master Volume screen like the one displayed in the photo. It would be easy to clear up a few characters that way.
I have been preparing a github repo for all of this progress and I plan to post it publicly after I get a few things cleaned up and a bit more documentation of how to create and program the module. If anyone is interested in helping out or playing along, please let me know!
Reply 6 of 20, by zuldan
Very interesting project. I think this will help us in years to come when these displays start to die. Please keep updating us 😀
Reply 7 of 20, by Delphius
I have finished putting together a repo with some minimal documentation and decided to make it public. Anyone who is interested can find the project here.
This latest revision cleans up a few things with a few additions like serial UART for debugging, better pin layout for serial programming, a dedicated reset jumper, support for single row display header, and a couple of standoff mounting holes to help support the weight of the sed1200emu while inserted into the MT32. If anyone has questions on any of the processes, let me know and I will try to add it to the readme.
Reply 8 of 20, by Delphius
I have been making some progress with this project with a little more experience. I was able to find a TFT LCD panel that is a good fit for a replacement, so I designed a shim for direct mounting into the MT32. Here is a sneak peek of how it is turning out.
The attachment sed1200emu.jpeg is no longer available
GIF below is animated if you click on it
The attachment vlc_JlWOY26hK4.gif is no longer available
It looks much better in person, but of course it has the limitations of a TFT panel. The benefit is it's full RGB capabilities so I have already implemented a few different color schemes that can be used. The controller can take MIDI input from the MT32 so I was able to make use of some extra space to add smooth and glowy VU meters for each of the MT32 channels . I am thinking of other ways to utilize the extra space and I am open to suggestions. Currently it is in a retro style color scheme which mimics the more of an amber CRT look. But I have kept a classic theme for those looking for something a little more original.
I plan to have the ability to change themes and options via UART and possibly even MIDI sysex so things can be customized how you like it. I am also looking at an OLED display that might also work, but will be limited to a single monochromatic color (probably white). But the TFT panel sort of keeps a bit of vintage charm so I am undecided if I will put the effort. The TFT panel is very inexpensive, where the OLED can sell between $10-20 a piece depending on supplier and shipping.
Reply 9 of 20, by Shagittarius
I've got a couple ideas:
1. A color pulse effect that uses a peak color when the channel is hit, and then gradient down to the base color when the channel is at the farthest specified point from usage. So for example you could have red be the peak, and the amber yellow be the base. As a channel was hit it would turn full peak red, and then decay at a reasonable rate to the base yellow.
2. For a more active display I think it would be cool if you were able to create radiating waves from each channel as it was hit, like imagine dropping a stone into a calm pool of water, and the interference pattern as the waves from each channel intersect each other. During a really active track the display would be lit up like a lighted swimming pool. Maybe the effect could be achieved with interference patterns alone fading in and out based on latest hit. I don't know how in depth you are thinking of the display but there are a lot of really cool ideas you could do depending on how advanced the graphics can be.
Reply 10 of 20, by Delphius
Shagittarius wrote on 2026-02-05, 16:22:
Thanks for the suggestions!
Currently this is already part of the affect of the VU meters, though it is slightly more subtle with this particular theme. There is a gradient from bottom to top that can go from three different colors / levels and the gamma of the VU follows the velocity as well. So it looks like they glow when the volume gets hotter. It is just a little more difficult to see through photos.
The display is being driven by a Raspberry Pi Pico now so there is plenty of extra head room to do all types of effects like this. It can technically even be skinned with BMP graphics as well. This is some of the early renditions and I will try to show some examples of the other themes that I have like neon and plasma which have a really cool affect. I also have a phosphor glow effect on everything just to give it a little more dynamics, or the classic theme makes everything flat like the original.
I will see how far I want to take it in the long run since adding more elaborate things might take a fair amount of time, when at the same time I don't know if it necessary to take the display too far outside of the bounds of MT32 natural aesthetics. I guess if there is a lot of interest in more of that then it might be fun to explore.
But also there is a bit of space to the very right of the display that could render info for other things like different types of MIDI events or activity, or it would be fun to add something that is related to DOS gaming specifically. One thought that I had was to create a system that recognizes certain sysex text messages and displays a graphical image related to the game. For example, when QFG1 loads and the message comes up that says "So you want to be a Hero", it could trigger a full fancy BMP graphic or animation to display. Little things like this to help expand some of the charm that the MT32 provides.
Reply 11 of 20, by Shagittarius
Delphius wrote on 2026-02-05, 16:57:
That sounds really cool. I agree that mostly standard functions would only be needed but we are all huge geeks and I can't imagine who wouldn't like to see cool related animations during Sysex messages.
Reply 12 of 20, by sl1pkn07
Hello. im hard interested in this project. can you put a picture with light? i want see how you adaped the new display in the fromtal of the mt32
greetings
Reply 13 of 20, by Delphius
sl1pkn07 wrote on 2026-02-12, 17:09:
greetings
Yes sounds good. I will post some more photos of how the display mounts inside the MT32 and the main driver board. I am finalizing some of the designs now and finishing up some testing with the UART / midi sysex control then I plan to release it.
I will be in touch about this soon.
Reply 14 of 20, by Delphius
Just a quick update on the progress.
I found a similar OLED display that works very well with MT32 and looks very bright and sharp. The disadvantage is that it is only one color so not as fun. In some ways I like the color TFT better since I have implemented different color themes. I have also implemented some screen savers that can be selected which are nice and colorful and fun. TFT and OLEDs can burn in so it made sense to have some protection built in. The screen will dim after 15 minutes, then go to screen saver after 45 minutes. These times can also be customized in realm time. I will be including a web interface to control the settings of the LCDs that uses all midi sysex so it is very easy to access and control. I am finishing up the shim for the OLED so essentially both LCDs will be ready and compatible to use.
I am also finishing the designs for the hardware and have them manufacturing now. A bonus inclusion will be to have the options to use the pico as a buffer for the MIDI input and control the rate to prevent all buffer overflows common to the MT32. This is still in theory but I am pretty sure I can make this work. The pico will be able to do both midi in and out so it also opens up some options for future updates. It may evolve out of being just a SED1200 emulator and into a more comprehensive MT32 mod.
I will keep in touch on the progress.
Reply 15 of 20, by Delphius
I have published my newest revision to my github repo. It supports two different types of display and now also includes an inline midi buffer that acts as a HardMPU mod to prevent buffer overflow.
Reply 16 of 20, by tnt23
Another take on drop-in LCD replacement.
Reply 17 of 20, by Delphius
tnt23 wrote on 2026-11-05, 19:46:
Another take on drop-in LCD replacement. […]
Oh cool! Does this mount properly to the SED1200 bracket size? I found it difficult to find generic displays that would cover this, but if you customized this one then it might be a great solution as well.
Reply 18 of 20, by tnt23
The carrier PCB was designed after original DM2011 LCD module, so mount holes and wire pads shall be identical. I don't have MT-32 front panel to test.
Also built opaque frame.
lcdframe1
lcdframe
Reply 19 of 20, by Delphius
tnt23 wrote on 2026-11-07, 13:49:
The carrier PCB was designed after original DM2011 LCD module, so mount holes and wire pads shall be identical. I don't have MT- […]
lcdframe1
lcdframe
Very cool, this looks really nice. Is the controller side ready to go as well? How do you plan on releasing this?
