First post, by LaC
So I just installed a 486 with heatsink and fan into my HP Vectra 486/66n. The DX2 66 was working fine, just wanted an upgrade.
Well the bios detects it as a DX4-100. But when booting ms-dos it locks up right after trying to load QEMM. So I reboot and hit F5 to bypass config.sys, and it works, but as soon as I try to list a directory or run edit or anything it crashes.
Seems like the CPU is bad? Anything else I can do to verify that?
Reply 1 of 14, by Disruptor
The DX2 has 5 Volt, the DX4 has 3.3 Volt. Are you sure your system supports 3.3 Volt processors?
Reply 2 of 14, by LaC
Disruptor wrote on 2024-02-09, 20:15:
I am not sure, no. The bios detects it.
Reply 3 of 14, by Disruptor
LaC wrote on 2024-02-09, 22:31:
I won't rely on that.
It's you who perhaps has a toasted DX4 then.
If I was you I'd either look for a power transistor like a 1085 or 1086 or a multimeter.
Reply 4 of 14, by waterbeesje
Those HP computers are notorious for being build as cheap as possible. So a 5v cpu means doet for 3v cpu cost more. When stelling computers in thousands, the few dollars saving make sense so it is quite possible the system does not support the DX4 out of the box but the bios is prepared for an overdrive or voltage converter.
My ibm Valuepoint just the same, my Compaq XE as well.
Stuck at 10MHz...
Reply 5 of 14, by LaC
Disruptor wrote on 2024-02-09, 23:05:
I won't rely on that. It's you who perhaps has a toasted DX4 then. […]
You're saying I might've fried the dx4 due to overvoltage?
Reply 6 of 14, by Disruptor
LaC wrote on 2024-02-10, 00:10:
dosis sola facit venenum
Reply 7 of 14, by Horun
Yes you might have fried the DX4-100 but maybe not, depends on how long you had it powered up. Did you look for docs on your HP to see if you needed to change jumpers for a DX4?
From the Maint manual I see no method to change cpu voltage so the only "factory" considered cpu replacement would be a Intel ODP with onboard regulator.
You also could try a "interposer" and a DX4....
Reply 8 of 14, by LaC
waterbeesje wrote on 2024-02-09, 23:59:
yup looks like it only supports Pentium Overdrive 83mhz.
https://web.archive.org/web/20030108133102/ht … /2bpv01951.html
ISSUE: Can the CPU be upgraded in the HP Vectra 486N, 486N & NI, or 486M & MI PCs?
SOLUTION: Yes, the processor can be upgraded to an Intel Overdrive/66, 486DX2/66-MHz or the Pentium (R) OverDrive P24T processor.
NOTE: The DX4-100 chip and the Intel Pentium processors are not supported in the HP Vectra 486N & NI and 486M & MI PCs.
The HP Vectra 486N PC (D26XX series) will not work with the Pentium OverDrive processor.
Reply 9 of 14, by Horun
Hmm it should support the ODP Intel DX4-100 (DX4ODPR100) as it is a drop in replacement for a DX33 or DX2-66, but finding one cheap can be a problem 😀
Reply 10 of 14, by MikeSG
This might not sound like much of an improvement, but later model DX2-66's exist with Writeback L1 cache.
Any with the code "&EW" in the part number, and I think all DX2-ODPR-66 are write-back.
Reply 11 of 14, by CoffeeOne
MikeSG wrote on 2024-02-10, 05:49:
Nope.
All DX2-ODPR-66 are write through.
Reply 12 of 14, by LaC
Horun wrote on 2024-02-10, 05:00:
yeah I think you get more bang for your buck with a Pentium overdrive. For some reason these demand a premium.
Reply 13 of 14, by CoffeeOne
LaC wrote on 2024-02-10, 16:49:
The Pentium Overdrive is even more overpriced than the DX4ODP-100.
But of course, if money does not matter, then go for the Pentium Overdrive.
More bang for you buck would be (most likely) an 3.3V Adapter socket and a Am5x86. But it's not clear, if this is fully supported by the Bios. On a Asus SV2GX4 the multiplier 4 of the Am5x86 does not work, if your bios version is 3.xx or older.
Reply 14 of 14, by LaC
CoffeeOne wrote on 2024-02-10, 16:58:
The Pentium Overdrive is even more overpriced than the DX4ODP-100. But of course, if money does not matter, then go for the Pent […]
Where do you get the adapter sockets?
