First post, by SuperLuke2003
I possess a Compaq Presario 2100 from the same joblot as the Toshiba while it has different issues I'm struggling to figure out how it's CPU socket works
If I use a screwdriver it will work just I'll end up gouging the socket and scoring the chip.
Was there a special tool that was for these specific Laptop style socket As?.
I'd like some assistance with figuring out what the best way of dealing with it would be.
Reply 1 of 8, by tauro
Ouch it already looks a bit damaged, be careful!
I've come across such sockets.
They have an open and a close position as marked by the padlock symbol. Use a flat screwdriver to slide it to the open position and then you should be able to remove the processor. If it doesn't come out easily I wouldn't force it.
Reply 2 of 8, by SuperLuke2003
tauro wrote on 2024-02-10, 20:42:
I've allready used a flathead (indicated by the damage) to remove it in the first place...it's a stupidly designed socket if you ask me.
Reply 3 of 8, by PcBytes
I've seen 370s done this way too. Found out the hard way by killing a 1100MHz Coppermine.
Reply 4 of 8, by wierd_w
It's a 'LIF' instead of a ZIF.
In Ye Days of Yore, (386/486 era), these were common. There is indeed a special tool.
Reply 5 of 8, by SuperLuke2003
wierd_w wrote on 2024-02-11, 08:34:
Would there be a place I can aqquire such a tool? Or make one perhaps?
I'd like to....not kill anything else trying to pry the socket open.
Reply 6 of 8, by wierd_w
The tool used on 386/486 systems is not good to use, as the spacing is wrong.
I'd be apt to instead, suggest 'carefully wiggling it out' using a plastic pry spudger, gently inserted under the edge of the chip.
One side, then the other, slowly working it up.
https://www.amazon.com/Plastic-Spudger-Openin … k/dp/B07MDKK8WG
There should be a small gap under the cpu to get under with said tool.
If not, start one with the corner of a credit card, then when you can get the spudger under, wiggle it out.
LIF sockets suck.
Reply 7 of 8, by lti
You aren't supposed to pry the CPU out, and you'll probably destroy that CPU if you tired (it isn't ceramic). It's meant to be a low-profile ZIF socket. You were supposed to use a screwdriver, but I always chewed up the edge of the CPU and socket like you did.
I remember seeing a video from AMD about them, but I don't know where to find it now (maybe Internet Archive due to its age). I did find this document that had instructions on page 31 (complete with pictures of a mangled socket):
https://web.archive.org/web/20050228161012/ht … _docs/24228.pdf
Reply 8 of 8, by bofh.fromhell
SuperLuke2003 wrote on 2024-02-10, 20:19:
I possess a Compaq Presario 2100 from the same joblot as the Toshiba while it has different issues I'm struggling to figure out […]
Tech tangent has a fight with a similar socket.
If you know exactly how the socket is supposed to move it helps:
https://youtu.be/8D0k8zXNv28?t=562
Takes a lot of force, tho i reckon some electronics cleaner like deoxit would lube it slightly to help some.
