First post, by MaLLy_R
- Newbie
Hello there... Great Vogons.
I own "PERIPHERALS ENTERPRISE COMPANY GW202".
http://mally.tim.com.pl/8bit_isa/MULTI_ ... 2_1(&).jpg
Card seems to work so I wanted to expand it with second COM.
I added missing chips (tested, working) and set jumpers according to instructions:
(https://www.minuszerodegrees.net/manuals/GW20 … rs%20Manual.pdf)
Bios sees COM2 but devices connected to it are not working.
What could be the problem? I already tested connections between pin header and 188 and 189 chips, they seems to be similar to COM1.
I'm sure 8250 is working, i tested it i another card.
Also when I pull-out 8250 from socked COM2 is no longer active in BIOS, so there is some kind of communication.
Can any one know what is the issue?
MIDI. I like MIDI... A lot! (Also stuck in 8bit PC era)
