First post, by Jackhead
Im a little bit worried about some readings using a new PSU for older hardware.
I read i shoud go min 25A on 5V rail.
ATm i using a Bequite! System Power 9 on my 486 what has 24A on 3.3V and 15A on 5V rail combined 103W.
I run this PSU over a year now without problems. And my 486 is filled up with hardware (ISA/VLB). So i wonder what is on that point going 5v with 25A+?
Or is that combined 3.3V/5V with 103W ok? Anyone really have damaged parts from to low Ampere on 5V ?
Reply 1 of 2, by rasz_pl
no you wont damage anything with less capacity psu, worst case it will be shutting down on peak load
Reply 2 of 2, by danieljm
25A on 5V is usually the minimum recommended specifically for an Athlon system. If your 486 is running stable, you don't have anything to worry about.
