First post, by leaves
Hello,
i try to run Technomage currently, - my main issue is, it will always defaults to a forced windowmode with a Frame attached, and i can not remove it.
I'm trying to use dgVoodoo to fix the issue, unfortunatly it won't run with Technomage.
I also tried the InstasllDDRawCOMRedirection Fix, that changes the ddraw.dll path in the Registry. (see attached)
I saw that it may fixed the issue for some, but not for me. Does anyone have the ability to run the Game on Win11, with dgVoodoo currently?
Also, the Game is AbandonWare, so if anyone wants to try: REMOVED
Greetings and thanks in Advance,
Leaves
