First post, by mita
Hi,
I try to repair an MB, see the closest MB on retroweb: https://theretroweb.com/motherboards/s/pcpart … ib804ds-35-8804
My MB is a bit different on the oscillator circuit and the power section, see the attached picture. The symptom: there is no clock, CLK out - pin 3 I assume - is about 3.4VDC on the scope. I replaced the crystal but the situation is the same. I was not able to find datasheet for this IC therefore I am asking help to locate one. Unfortunately I was not able to find a similar one. Maybe the closest is the ISC9169 but the pinout and the number of pins are different I am sure. Pin 1 of the SC653 is GND, pin1 of ISC9169 is VCC. Interestingly pin2, pin3 is the same, the xtal connections.
Any help, suggestion is appreciated!
Reply 1 of 2, by Thermalwrong
Search for just "imi sc653" minus the quote marks. The last letters of parts like this after the numbers, say they're SRAM, PLL or DRAM etc are usually things like the package type, revision, operating temperature - so searching for the package name open ended like this often results in better hits.
There's a full PDF on the first page of google - uploaded here just in case it goes away.
Reply 2 of 2, by mita
Thermalwrong wrote on 2024-02-20, 22:04:
Thank you your help! Document sent to admint to upload .
