First post, by Nunoalex
Hi guys!
I got this very interesting ACER V12LC socket 5 motherboard with a Pentium 100
The board is a LPX form factor and I cant make it boot
The POST analyzer reports code "dc" I have never seen this post code before.
The BIOS chip is ACER not Award or AMI... and I couldn't find any information regarding this post code
Sometimes when I put other SIMM modules or I remove them it reports code 1C so the board seems to be alive
I have reseated the keyboard chip, the BIOS, CPU and even replaced the DALLAS ... all with deoxit
I even tried asking ChatGPT but Georgina (that's what I call the chat bot) didnt have any answers
Thanx 😀
Reply 1 of 6, by Horun
Acer code 1c is "testing memory refresh". The 5v led is not lit, do you have stable +5v ?
Reply 2 of 6, by Nunoalex
Horun wrote on 2024-02-25, 17:23:
Hi!
My problem is with code "dC" ... I cant seem to find any reference to it
Yes +5v is fine... that post analyzer card has the 5 volt led broken, but its fine
Reply 3 of 6, by Nunoalex
anyone ? :p
Reply 4 of 6, by rasz_pl
I dont see any buttons on your card, can it rewind to show past codes? are there any other codes or just this one?
BIOS might be corrupted, do you have ability to flash another bios from theretroweb and swap bios chips?
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 5 of 6, by Nunoalex
rasz_pl wrote on 2024-02-29, 12:08:
thank you for the help
no the analyzer card doesn't scroll back past codes... it was a really cheap one
but if I plug in a PS2 keyboard I can see it display other code before landing on dC
The sequence is really fast
And when I remove all the memory it does land on 1C error code that is related to memory on most other mainstream BIOS brands
so somehow it seems to be working or at least running some BIOS code...
I will try your suggestion and try to find bios for this board and flash them on it
Reply 6 of 6, by rasz_pl
looking at https://web.archive.org/web/20010716001033/ht … es/acerbios.htm it almost feels like upped nibble is corrupted
1C does actually make sense as "Memory refresh system tested" signaling 'no memory' error code
record it with a phone, bonus points if it has slomo 😀
