First post, by nahum
"Upgrade 2012 DOS MPlayer to Version 1.5"
Hi,
Using the following Hotlinks as a baseline:
link
Are there any savvy DJGPP coders able to upgrade DOS 2012 mplayer to its present version 1.5, using the following DJGPP cross compiler GCC version 12.2.0 build script from:
#!/usr/bin/env bash# Path to DJGPP cross compilerexport DJGPP_PREFIX="/Users/owner/djcc"export PATH="$DJGPP_PREFIX/bin:$PATH"# Your cross compilation targetTARGET_ARCH="$DJGPP_PREFIX/bin/i586-pc-msdosdjgpp"# Download MPlayer source codeMPLAYER_VERSION="1.5"MPLAYER_ARCHIVE="http://www.mplayerhq.hu/MPlayer/releases/MPlayer-${MPLAYER_VERSION}.tar.xz"MPLAYER_SOURCE_DIR="MPlayer-${MPLAYER_VERSION}"# Download MPlayer sourceecho "Downloading MPlayer source..."wget -c "$MPLAYER_ARCHIVE" || exit 1tar -xf "MPlayer-${MPLAYER_VERSION}.tar.xz" || exit 1cd "$MPLAYER_SOURCE_DIR" || exit 1# configure help./configure --help >> junkc.hlp 2>&1# Configure MPlayer for cross-compilationecho "Configuring MPlayer for cross-compilation..."./configure --enable-cross-compile \--cc="${TARGET_ARCH}-gcc" \--target=i486-DJGPP \--disable-mencoder \--enable-static \--disable-networking \--disable-dvdnav \--disable-dvdread \--disable-cdparanoia \--disable-x11 \--disable-alsa \--disable-arts \--disable-sdl \--disable-freetype \--disable-bluray \--disable-liba52 \--disable-libdca \--disable-mpg123 \--disable-liba52 \--disable-libmpeg2 \--disable-v4l2 \--disable-joystick \--disable-dvb \--disable-xvid \--disable-x264 \--disable-vdpau \--disable-libmpeg2 \--disable-libvorbis \--disable-mad \--disable-x264 \--disable-xvid \--disable-inet6 \--disable-libcdio \--disable-cddb \--disable-caca \
--disable-dvdread \--disable-dvdnav \--disable-faad \--disable-libopenjpeg \--disable-mpg123 \--disable-libopus \--disable-libavcodec_mpegaudio_hp \> configure.log 2>&1 \|| exit 1# Compile MPlayerecho "Compiling MPlayer..."gmake > make.log 2>&1 || exit 1# Test compiler functionality by compiling a hello world programecho "Compiling hello world program for testing..."cat > hello.c <<EOF#include <stdio.h>int main() {printf("Hello, world!\\n");return 0;}EOF"${TARGET_ARCH}-gcc" hello.c -o hello || exit 1echo "Compilation complete."
Thanks in advance!
