First post, by sdz
Hello,
The motherboard is an Asrock Z77 Extreme4, with 2 PCI slots (via some Asmedia PCIe to PCI bridge).
1.79 MiB
If a single Voodoo 2 card is installed, regardless of the PCI slot, it works fine.
73.2 KiB
If two Voodoo 2 cards are installed (with or without the SLI bridge), right clicking on the desktop -> properties:
77.45 KiB
Or when trying to run Quake 2 (dxdiag fails in a similar way):
41.71 KiB
I have tried the following drivers:
v2-w9x-3.01.00 , v2-w9x-3.01.01 , voodoo2-30202 , rkv2dx6303
fastv2-win9x-v30 , fastv2-win9x-v35 , fastv2-win9x-v40ge , fastv2-win9x-v46
It fails in the same way with any of the drivers.
Edit: with a single card, under W98, mojo.exe detects it, and reports the expected info (FBI memory, TMU memory etc). With two cards under W98, it detects only one cards, and incorrectly reports the info (FBI 0MB, Bogus number of TMUs).
Under DOS both cards are detected and the info reported is correct.
Any suggestion is highly appreciated 😀
Reply 3 of 8, by DarthSun
sdz wrote on 2024-02-29, 15:35:
Any other suggestions? 😁
I see APU is a 2D card. Maybe something is missing from the system drivers or the installation is incomplete? DX9.0c 2004-2006, which also supports 98.
Is there a Win98 driver for the APU? Although if it's ok with 1 card, it should run with 2.
I tried it on a more modern machine, and it's ok there too.
B450 Pro
R3800X - 2C/2T SMT off - 4C/4T SMT off
2xMighty2 V2
2D API running - QFX3500(NV7900GS), W98 driver is included
Chinese PCIe to PCI duo adapter
FastVoodoo2 4.0 Gold edition
DX9.0C, UOSP98, Loew drivers - SATA AHCI/BigDrive/mem/ USB, KernelEx, Intel ICH10/X58 (yes, this is also good for it, surprising).
The question mark in the device manager is GTX1650+HDMI sound, there is no modernized driver for these, only GTX1650/VESA Uni.
359.32 KiB
397.17 KiB
289.15 KiB
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 4 of 8, by sdz
Thanks for all that info!
The 2D card is running with the generic VGA driver, there isn't a driver for W98.
I tried with newer DirectX version, 7.0A, 8.0, 8.1B, and it didn't make a difference.
I'll try installing the Loew drivers, KernelEx and see if it helps. Right after I reinstall W98, as I just bricked it.
Thanks again!
Reply 5 of 8, by sdz
I tried with Loew's SATA AHCI/mem(W98 fails to boot with it)/ USB, KernelEx, Intel ICH10/X58, i740 graphics card (onboard was disabled) with or without external PCIe to PCI bridge (XIO2001). Same result.
I have not tried with the unofficial service pack yet.
Reply 6 of 8, by DarthSun
sdz wrote on 2024-02-29, 20:26:
If the AHCI driver is on, it must be turned on in the BIOS, otherwise it will not start. The memdriver must also handle memory larger than 512MB.
I first installed it on S775 Asus P5Q. The correct installation is a relatively complicated and long process. I finalized it here, then transferred the SSD to RyZen, it booted, and it started inserting the drivers there as well. +3 reboots, then it's done.
I have an X99 Haswell Xeon from Intel, I haven't tried the SSD on it yet, but I think it would run smoothly there too, but I should put an older video card in it, because it has GTX1650(Win10-11) and HD6850(XP). On the NV side, the 7900xx is the max for which there is a Win98 driver. I won't change this anymore.
1 more suggestion: DX8 is not enough, it does not work well on relatively modern hardware, it is worth installing the latest (W98)-08 Dec 2006 DirectX 9.0c.
Reply 7 of 8, by mihai
looks to me like a pci memory mapping issue with windows 98 (i am quite sure there would be no issue with windows xp).
first idea would be to allocate the least possible amount of ram to the 2d video card, while disabling all extra devices in the bios. there used to be a little utility to view the memory allocated to pci devices allowing as well manual remapping but i cannot seem to find it.
Reply 8 of 8, by sdz
@DarthSun
The memdriver didn't really work for me, I had to undo the changes. The system has 16GB installed, but I limited it to 512MB from system.ini
@mihai
Yes, it works well under XP on the same machine.
I did try changing the amount of iGPU allocated RAM, and also disabled it and used an external 2D card (8MB).
Also tried with all peripherals enabled in the BIOS, and with a minimal set (disabled audio, lan, second PCIe to SATA controller etc).
Nothing changed.
Thanks for the help!
