First post, by Marco
Hi all,
situation:
- 1x ISA HDD Controller Card Winbond allowing 2 HDDs on one port
- 1x SB16 CT2830 with IDE interface
- 2x HDD
- 1x CF
- XTIDE BIOS
Question:
- Is there any recommendations which setup to use? On later Busmaster sytems it was back in the days recommended to use primary and seconday IDE ports when using 2HDDs instead of master/slave setup e.g.
- Is this similar here meaning I should put major production storages on Winboard 1x and the other on SB IDE interface?
- Or is it a mix like: yes do the separation but not on SB IDE interface as it's slow.
Thanks all
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
