First post, by MilesPrower2001
Recently got a 286 Kouwell KW-241 pc. Also picked up a POST card to see any codes. Everything checks out fine, but it only boots into the BIOS sometimes. I have a feeling it’s a RAM problem, but if it was, I wouldn’t boot at all. The only cards I have in it are the EGA card and the FDD/HDD controller. I really need some help with this thing.
Reply 1 of 13, by Nexxen
Bad ram can POST and BOOT fine until it gets hit in the non funtional cell.
Add a pic of your board in high res, it'll help visual inspection.
Find CheckIt 3.0 by TouchStone Software. There is a ram test if I'm correct.
If present, try loosening the ram timings in BIOS.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 2 of 13, by MilesPrower2001
Here’s that photo. I did have a battery that was leaking and I took out. There was some corrosion near the keyboard connector. I dropped a few drops of IPA and vinegar just to take card of that. Might take out that chip and clean under it, replace it with a socket.
    1.77 MiB
    1.27 MiB
Reply 3 of 13, by Nexxen
I'm unfamiliar with this kind or RAM, but reseating the chips and cleaning the sockets is a must at this point.
https://theretroweb.com/motherboards/s/kouwel … electron-kw-241
Check jumpers.
Reply 4 of 13, by MilesPrower2001
Been reseating the ram so many times. All the jumpers look correct to the paperwork. I haven’t cleaned the sockets yet. You think automotive contact cleaner would be okay? I don’t want to have to wait for Deoxit to come in.
Reply 5 of 13, by Nexxen
MilesPrower2001 wrote on 2024-03-03, 22:39:
No idea, sorry. Automotive could be too harsh. Some alcohol and a good scrub could be enough.
Checkit 3.0 and test the ram. IDK if it works for this type but it won't hurt.
Reply 7 of 13, by Nexxen
MilesPrower2001 wrote on 2024-03-03, 23:01:
Any idea how to get Checkit on to a floppy? 5.25 or 3.5. Could I just use a usb 3.5 floppy drive with my Windows 10 computer?
Yes. Boot with Dos and then run checkit! 😀
Reply 8 of 13, by MilesPrower2001
Cleaned the sockets and nothing.
    1.73 MiB
    1.46 MiB
Reply 9 of 13, by MilesPrower2001
Now it just booted into the BIOS twice. I had the lock unplugged and that locks keyboard input. Plugged the lock back in now it won’t boot. Don’t know if it helped, but I did take the jumper out of the pins near the CPU
Reply 10 of 13, by Nexxen
Ok,
- anything hot at the touch?
- if you push the chipset chips, does it make a difference?
When it boots, can you type with the keyboard?
Btw, maybe it's not ram related, but HDD controller.
What happens without the controller on? Straight to bios os it goes on to "no boot disk, insert boot..."?
Reply 11 of 13, by MilesPrower2001
The only thing I’ve noticed that gets warm is the CPU. I’ve turned it on with nothing in it, and still nothing. I’ve tried pushing on the ram. Nothing. On the cpu. Nothing. On the bios chips. Still, nothing. I’m at a total loss.
Reply 12 of 13, by Nexxen
MilesPrower2001 wrote on 2024-03-04, 00:48:
Do something else to relax.
I'm not the best to help, someone else with more experience and knowledge will show.
This is so close to a solution, just be patient 😀 Trust me.
