First post, by KoniTec
Hi All
I have installed simcity 200o in dos 6.22, and it runs fine if the disc is in the CD Rom drive (as expected). However if i forget to put the disc in the drive, I get the message that the disc is missing from D: drive with the Abort, Retry, Fail, Ignore message, but i am unable to actually press any key for those options.
No matter what key i press nothing happens, even if i put the cd in the drive, and i have to hard reset the pc and start again.
Anyone know if this is a common issue, or if there is a fix for this?
Many thanks
KoniTec
Reply 1 of 4, by elszgensa
Wild guess, are you using a USB keyboard through legacy PS/2 emulation? Try a native PS/2 keyboard instead, or at least one of those passive USB-to-PS/2 adapters (the keyboard has to support that though - many new ones don't).
Reply 2 of 4, by KoniTec
elszgensa wrote on 2024-03-05, 12:57:
Im using original mid 90's hardware, including a native ps/2 keyboard. The keyboard works fine the rest of the time, its just when this error happens when trying to boot simcity 2000 without the cd in the drive, it wont accept any keyboard input.
Even if i try to read a floppy in drive A: without a floppy disk in, i get a similar 'abort, retry, fail' option, but the pc happily accepts keyboard input for those.
Reply 3 of 4, by elszgensa
KoniTec wrote on 2024-03-05, 14:18:
I could reproduce the issue. sc2000.bat runs intro.exe, then sc2k.exe. It's this intro.exe that hangs - i.e. it's not a prompt waiting for input, but a hard freeze - in QEMU it doesn't even look right, the text is shifted all over the place. Run sk2k.exe instead (this might make willtv not work as intended, since the .bat is handling that too), or comment out intro.exe in the .bat and you should be golden.
Looks like Maxis implemented code paths for "no CD drive found" or "wrong disc" (says it couldn't find the CD and will skip the "in-flight movie" (intro), then let you play), but they somehow missed the "empty drive" case?
Reply 4 of 4, by KoniTec
elszgensa wrote on 2024-03-05, 15:08:
Oh wow, so its an original bug. Ok no worries, thanks for looking into it. I will do what you suggested and work around the issue.
Many Thanks
KoniTec
