First post, by Rodney Betters
I apologize if this is a stupid question, but I'm seeing a lot of conflicting info online regarding this. I want to connect my Audigy 2 ZS to an external DAC via it's digital output. Question is, will I lose hardware acceleration and EAX in doing so? Or is EAX simply passed through the digital out, bypassing the DAC on the card?
Reply 1 of 6, by Joseph_Joestar
EAX works fine when using the digital (SPDIF) out on SBLive and Audigy cards.
I have an Audigy 2 connected to a set of Cambridge SoundWorks Digital Speakers (2.1 system) via coaxial SPDIF cable, and there are no issues with EAX whatsoever.
My retro stuff
Reply 2 of 6, by Rodney Betters
Hey that's great. I appreciate the response, Joseph. What about volume levels in your OS? I'm using Windows XP - so for optimal sound quality, would the windows volume setting need to be 100% for digital output? I've read that there's clipping or distortion that can occur at higher Windows volume levels so I currently have my Windows volume down a few notches from max.
Reply 3 of 6, by Joseph_Joestar
Rodney Betters wrote on 2024-03-07, 14:27:
There was recently a discussion about that here: SPDIF output level
I usually keep my volume sliders at max when using SPDIF, but that's just out of habit. Haven't noticed any distortions so far.
My retro stuff
Reply 4 of 6, by Rodney Betters
What kind of miniplug connector are you connecting to your soundcard? The manual contains contradictory info. On one page is says to use a 3.5mm mono minijack to RCA for the digital out, while a later page says to use a "4-pole" 3.5mm mini to RCA. I'm assuming I need to use a mono minijack connection and that the 4-pole would be used for digital surround sound speakers.
Reply 5 of 6, by Joseph_Joestar
Rodney Betters wrote on 2024-03-07, 15:35:
I use a simple 3.5mm to RCA mono adapter. Works great for stereo sound.
If you're planning on using a digital connection to a digital 5.1 speaker setup, I think you may need a different adapter. Don't have either of those, but I remember seeing something like a mini-din plug in the manuals.
My retro stuff
Reply 6 of 6, by Rodney Betters
Wonderful. Thanks again, Joseph. I decided to order a mono 3.5mm to RCA cable. Should have everything up and running next week.
